1978 460 Cylinder and distributor layout - 460 Ford Forum
post #1 of 5 (permalink) Old 09-26-2006, 11:06 AM Thread Starter
A groundhog took out my F250. He chewed up the spark plug wires. So basically I have an engine with distributor and have no idea what post on the distributor goes to what cylinder. Does anyone know the following:
1. Cylinder number layout of the engine if I am looking at it from the front of the truck with the fan blade against my chest.
2. Cylinder number layout of the distributor.
Thanks,
Sam
shopkins is offline
post #2 of 5 (permalink) Old 09-26-2006, 11:25 AM
pedal2themetal45 is offline
post #3 of 5 (permalink) Old 09-26-2006, 11:25 AM
Danny Cabral's Avatar
firing order
Turn #1 cylinder to TDC (read on harmonic balancer) on the compression stroke (when air is forced out spark plug hole), remove ignition cap and look at which cap terminal the rotor is pointing to (this is #1 terminal on cap).
http://boxwrench.net/specs/ford_429-514.htm
May God's Grace Bless You
Danny Cabral is offline
post #4 of 5 (permalink) Old 09-26-2006, 11:34 AM Thread Starter
THANKS!
Thanks Guys
shopkins is offline
post #5 of 5 (permalink) Old 09-26-2006, 04:04 PM
I like how that picture is of a chevy block. It's the correct ford cylinder numbering, just thought it a bit funny that they used a cheby block for the actual pic.
ScottJackson is offline
