How much weight is saved with aluminum heads? - 460 Ford Forum
post #1 of 39 (permalink) Old 12-28-2006, 10:14 PM Thread Starter
Could somebody please refresh my memory, what is the total weight savings with the running of aluminum heads, all other things being equal?
Roy
pencilneck is offline
post #2 of 39 (permalink) Old 12-28-2006, 10:18 PM
richter69
Guest
Posts: n/a
Quoted: Post(s)
want to say its like 80lbs, your back will thank you when you need to pull one.
post #3 of 39 (permalink) Old 12-28-2006, 10:25 PM
sounds about right..i can remember hearing it was around 100 when combined with an Al intake.
I like cars.
BB68coupe is offline
post #4 of 39 (permalink) Old 12-28-2006, 10:51 PM
My Fox stangs front fenders raised up 1/2" when I switched to aluminum.
1986 mustang 514 ci. OH-FACE RACING
46686stang is offline
post #5 of 39 (permalink) Old 12-29-2006, 12:40 AM Thread Starter
Folks are going through lots of bucks to try to get good power out the the 4.6 modular engines in the Thunderbird and I'm wondering why I couldn't drop a bullet proof big block in there with as much aluminum as I can get on it to save weight? They did come equipped with a 5.0 so that would make more sense to build, I guess. The big block just makes so much torque and it runs effortlessly while making big power, those smaller engines always sound like they're about to blow up. That freaking 89 Tbird I bought the wife is a great handling car, I wouldn't want to ruin that with too much weight, though. I suppose I could use that same pricipal and run aluminum heads and intake on the 302 and build a light weight small block to suit the car better. Any strong opinions on the subject? Thanks, Roy
Roy
post #6 of 39 (permalink) Old 12-29-2006, 06:41 AM
4.6 weighs to much itself. I read an Edelbrock add once that claimed 70 pounds difference in their heads vs. the cast iron.
jpierce55 is offline
post #7 of 39 (permalink) Old 12-29-2006, 09:50 AM
I weighed my Kaase SCJ's when I did my rebuild. They were 60# lighter than the iron heads, on the bathroom scale I used. I don't remember all the specific weights, but do remember Heads, Aluminum Intake, & Aluminum Water Pump took off 100# from the iron parts. But I do think my aluminum fined valve covers were WAY heavier than stock.
Ken
SCJF350 is offline
post #8 of 39 (permalink) Old 12-30-2006, 01:05 AM
Never seen a 4.6L with cast iron heads... I assume you intended to say BBF since Edelbrock does not make a head for the 4.6L ?
Do you know how much a 4.6L ford weighs, since you feel it is too much ?
Steve
68xr7cat is offline
post #9 of 39 (permalink) Old 12-30-2006, 05:50 AM
Steve
Yes some 4.6 came with Iron heads
Randy
cougar1969 is offline
post #10 of 39 (permalink) Old 12-30-2006, 07:00 AM
Steve
I think what I stated was simple enough to figure out, especially for one such as yourself :roll:
I was stating a 4.6 weighs to much to consider it over a 460, it is not that much lighter esp a 460 with aluminum heads. I don't know overall weight, I do know block is 154 (iron) and heads are 44each. So A bbf block is like 220 and the aluminum heads about 40each. So what is the crank weight of the 4.6 I don't know, or the extra weight of the cams. Considering the size I imagine the intake weight is similar. The fact is that sbf and mod's are not as much lighter as people think. Even a 2.3L is not as much lighter as most think. Are you going to enlighten us all again?:roll:
I was stating the Edelbrock 460 heads are 70lbs less a pair.
post #11 of 39 (permalink) Old 12-30-2006, 02:52 PM
No, you can stay unenlightened :roll:
I just hope others here will do some independent research before accepting your statement that the 4.6L is too heavy.
Steve
____________________________________
Got chrome moly rings?
68xr7cat is offline
post #12 of 39 (permalink) Old 12-30-2006, 03:12 PM
Steve
Most anybody here who reads my posts knows I only like 4 bangers/6 bangers/ and big blocks. So no matter what a small block or modular is just a door stop to me. Don't believe me? Come over to the garage and look what my doorstop is.
I see no reason to ever use a 4.6 unless it is already in there.
post #13 of 39 (permalink) Old 12-30-2006, 03:17 PM
Coupe Devil's Avatar
Hey man check out http://members.tccoa.com/392bird/ Handles well and GOES LIKE STINK....Its a buddies car in Clarksvilel Tn. Its been in a couple magazines, Bruce is a great guy and will talk your head off if you start askin about the build on the car..
1990 GT, 347 / 76mm turbo setup OUT AND GONE!
New setup going in. Dove headed 545 with a plate kit to 400, progressive, Th400 etc. etc. etc.
Coupe Devil is offline
post #14 of 39 (permalink) Old 12-31-2006, 01:53 PM
From FRPP's 2007 catalogue:
Did you know…
That an aluminum 4.6L block weighs approximately
85 lbs. while the iron versions weigh approximately 155 lbs.
Did you know…
The new 3-valve 4.6L engine in the 2005-07
Mustang weighs only 420 lbs. dressed.
7.5L/460 “SUPER COBRA JET”
550HP FORD RACING PERFORMANCE
CRATE ENGINE ASSEMBLY
Shipping weight approximately 670 lbs.
500 hp 4.6L's are pretty common nowadays. 600-750+hp doesn't take much more effort. They're nothing to sneeze at.
Joe
1999 Cobra Vert SOLD
1970 Lincoln Continental Mark III GONE
Protect your hobby. Join the SEMA Action Network ===> www.SEMASAN.COM
Thunderchild is offline
post #15 of 39 (permalink) Old 12-31-2006, 04:41 PM
I have seen 750hp supercharged 4.6L's and they don't last long at all, not the ones I have seen (and built by a pro 4.6 builder), that is with forged cranks, steel rods, and aftermarket blocks. I kind of figure for that money I would want something to last, esp. with $200 an hour tunning cost. Fast yes, something to sneeze at yes. It is no different then the rice burner engines; fast today gone tomorrow. But it is pointless to fight over.
670lbs? The BBF is a bit lighter than that I think? Seems like it would have to be since the listed weight of a stock iron headed 460 is 720lbs.
