385 vs FE - 460 Ford Forum
post #1 of 53 (permalink) Old 03-11-2007, 08:30 PM Thread Starter
385 vs FE
I could use some help/opinions/suggestions.
I am starting to restore a '66 Fairlane with a 390 and 4-spd Toploader (not original, from a 68 Merc I think) with an 8" rear end. After several months of researching building an FE it seems the 460 may be a better choice. I'm looking to get 500hp (at the flywheel) and would like to add a mild (100~150) shot of nitrous later.
I bought the car because of the the big block and manual tranny and liked the 390 because it was a period correct motor, but I'm not a purist and I'm going for a resto-mod not an authentic restoration.
This car is not going to be a daily driver and I hope to have it at the dragstip as often as I can make it there, but I want it capable of running down the highway. I want to stay on a budget as much a possible and would like to reuse the short block (maybe minus pistons) of whatever motor I go with. This will be my first full engine build so I want to do it up right just don't want to go broke doing it.
What do you guys think for that application? I assumed the 8" would have to be replaced but don't want to have to replace the tranny also if I change the motor. What are the pro's and con's of the 385's vs the FE's (on a budget and in a Fairlane)
66f'lane is offline
post #2 of 53 (permalink) Old 03-11-2007, 08:47 PM
you can make 500hp with a 390 but i think in the long run,it will be cheaper to build a 460, plus the room for growth in the 460 is rediculous. 500 HP isnt that difficult and the 385 series itself is only a lil heavier than a 390. Parts are easier to find AND theyre cheaper, and like i said room for growth is ALL there.I went through this dilema a few months ago but decided to take the plunge since horsepower is addicting and you know once you get that 500HP youll want a bit more,then more,then more after that.. As for the tranny im not too sure but i know the bellhousing will definately have to change if its even possible.
MauriSSSio is offline
post #3 of 53 (permalink) Old 03-11-2007, 08:50 PM
500hp and a 150 shot of nitrous is doable onan FE. One oops and it's gone
Build a 460 based motor, it can handle an oops.
Faster cars, running tractors, and rain in TX - I can dream
FE_rex is offline
post #4 of 53 (permalink) Old 03-12-2007, 05:13 AM
Barry_R's Avatar
A lot depends on your future plans and what you already have. The power is fairly easy with today's stroker stuff & heads - but you'll be closer to the limit on the 390 FE.
The 460 has more potential and a lower build cost - but the lower cost will be offset by a need for motor mounts, bellhousing, headers, etc - as well as the cost of the core engine (FWIW you already have the 390).
You pick....
Barry R.
#1 Horsepower FE Ford - Engine Masters Challenge - 2005, 2006, 2007, 2008, 2009, 2010
Warehouse Distributor for:
Scat, Probe, Blue Thunder, Diamond,
Clevite, Holley, Federal-Mogul, Comp Cams, more.
www.survivalmotorsports.com
(248) 931-0358 or (248) 366-3309 shop
Barry_R is offline
post #5 of 53 (permalink) Old 03-12-2007, 06:34 AM
Danny Cabral's Avatar
I don't know anything about an FE engine...but what exactly is wrong or inferior with them? Excuse my 'FE ignorance'.
May God's Grace Bless You
Danny Cabral is offline
post #6 of 53 (permalink) Old 03-12-2007, 07:19 AM
RJP
Nothing wrong with an FE, just a earlier design and not quite as sophisticated as the 385 series. Some say the rockershaft design is primitive, pushrods are too long and can be troublesome, strange head and intake manifold arraingment, bad oiling system, [never understood that one as its the same basic system as a SBC] The positive side of an FE is they are relitivity compact engine for the displacement, not too heavy with an aluminum intake manifold [around 610-620 lbs] and make decent power/torque with stock or close to stock parts and when built right and taken care of have the reliability of an anvil. They can get expensive to build esp. if you want a 427 or 428 and need a core. Alot of cars would not be the same without an FE such as a GT 40, 427 Cobra, 64 Thunderbolt, 428 CJ Mustang, any 'R' or 'W' code Galaxie or Fairlane built in the 60s. FE have a very loyal following as they are still very competitive in racing and are very rich in racing history. [First American engine to win Le Mans and did it more than once and countless wins in NASCAR, USAC NHRA etc] Even today the FEs are still collecting their fair share of wins in Galaxies, Mustangs, Fairlanes and other bodys that didn't orig. have FEs installed.
RJP is offline
post #7 of 53 (permalink) Old 03-12-2007, 08:24 AM
Thanks RJP!
Two more questions, if I may:
Is there a large availability of aftermarket performance parts for the FE engine (like the 460)?
Can you bore and stroke an FE engine for large cubic inch displacement?
post #8 of 53 (permalink) Old 03-12-2007, 09:12 AM
Barry_R's Avatar
:roll:
I have a little bit of an FE habit... :lol:
Please follow the links below for some FE info...
http://www.survivalmotorsports.com/FE_EMC_article.html
http://www.survivalmotorsports.com/FEparts.html
http://www.survivalmotorsports.com/FE-Engine-Kits.html
http://www.survivalmotorsports.com/FEKitTech.html
Barry R.
Barry_R is offline
post #9 of 53 (permalink) Old 03-12-2007, 09:17 AM
Quoted: 105 Post(s)
About 500 inches is their safe usable limit ... you have to remember that these engines began life in the 50's with cubic inch displacements of 330 and 352.
post #10 of 53 (permalink) Old 03-12-2007, 12:09 PM
RJP
Thanks RJP!
Danny, There is a big aftermarket parts supply thanks in kind to Cobras: kit and orig., Shelby Mustangs and the popularity of Mustangs, Galaxies and Fairlanes. I can think of 4 cos. that make 427 blocks in iron and aluminum, Shelby Am., Genesis, Pond and Dove. Heads are done by Edelbrock, Blue Thunder & Shelby Am. The limiting factor for displacement is the small bore centers and the limited space needed to swing a big stroke crank. As I understand about 530" is the upper end limit to an FE.
RJP is offline
post #11 of 53 (permalink) Old 03-12-2007, 01:35 PM
The largest stroker kit ive seen for the 390 is 440 cubic inches i think more is possible with the aftermarket genises block,but then again more is possible with the A460 block
post #12 of 53 (permalink) Old 03-12-2007, 01:50 PM
jm
IMO, if it was me i would build a 385 than a fe. i hate the fe's so much i would install a small block chev than a fe if it was the only 2 motors left in the world.
jm is offline
post #13 of 53 (permalink) Old 03-12-2007, 02:39 PM
Well of course...we all would (that's why we're here).
See, this is what I'm referring to. Why do some people hate the FEs so much? (I've often heard this.)
post #14 of 53 (permalink) Old 03-12-2007, 03:18 PM
jm
core shift problems, valve train "using custom push rods to get geometry right", heavy and weak rods, poor oiling, cylinder heads suck,aftermarket stuff is VERY$$$, PLUS CUBE vs cube the 385 would run circles over the very outdated fe.
jm is offline
post #15 of 53 (permalink) Old 03-12-2007, 03:23 PM
I guess jm will have to answer that one!As for me there are only two things I dont like about them.
1 The intake(or center head).Man that thing weighs about a million pounds(100lb).But thats an easy fix now.
2 The exhaust leaks.I have never had one that didnt develop one.And it seems like every time you go to fix it the bolt breaks off in the head.If you were building a new one a grade 8 would fix that.
Im talking about a stock to mild motor.Theres also SOME interchangeability probs.Overall I would say great motor for its day.In fact it set(and I think still holds)I dont know how meny records.
God bless
Lonnie
63galaxie2 is offline
