Timing retard in high gear - 460 Ford Forum
post #1 of 18 (permalink) Old 07-18-2007, 04:43 PM Thread Starter
Anyone running a timing retard for high gear. I hooked up my timing computer (MSD 8980?) and I'm curious as to what it's going to pick up if any. My timing is at 36 total right now but it seems like it's laying down in high gear. Thanks in advance!!!
jims91notch is offline
post #2 of 18 (permalink) Old 07-20-2007, 09:06 AM Thread Starter
Timing retard
TTT
ANYONE????
post #3 of 18 (permalink) Old 07-20-2007, 09:22 AM
dfree383
Guest
Posts: n/a
Quoted: Post(s)
Never Tried it, I have heard about it.......
:lol:
post #4 of 18 (permalink) Old 07-20-2007, 11:44 AM
Quoted: 105 Post(s)
Actually - "timing retard in high gear" is kind of a missnomer.
It's really a way to INCREASE ignition timing in the lower gears for better acceleration.
Your numbers may be different but here is the explanation of how it works. If your engine likes 36 of total timing, you set the timing at 39 and use the "high gear timing retard" to pull the timing back 1 from optimum to 35 in high gear when loading is the greatest and acceleration is at its slowest rate...
post #5 of 18 (permalink) Old 07-21-2007, 08:45 PM Thread Starter
Timing retard
I was guessing it was something along those lines. I'll give it a try and let you know how it works. Thanks for the help!!!
post #6 of 18 (permalink) Old 07-26-2007, 04:56 PM Thread Starter
Timing retard
Got the timing retard installed today. It pulls like an animal in 1 & 2 gear now and doesn't lay down in third like it used to. I have the timing at 39 degrees total and I'm pulling out 4 degrees in high gear. The weather was pretty hot and humid today but the engine didn't detonate as far as I could tell. The plugs look good. I'll keep you guys posted on the track results. Thanks again for the help!!!
post #7 of 18 (permalink) Old 07-26-2007, 05:42 PM
feetfirst's Avatar
Re: Timing retard
make sure you post 1/8 mile difference as well as quarter. Im interested to see what happens.
feetfirst is offline
post #8 of 18 (permalink) Old 07-29-2007, 06:18 PM Thread Starter
Re: Timing retard
Will do. Hoping to have some numbers by this Tuesday. Unfortunately they will be 1/8 mile only. I'll be sure to make a few passes before I plug in my timing retard and note the differences. I'll keep ya posted. Thanks.
post #9 of 18 (permalink) Old 08-01-2007, 09:13 AM Thread Starter
Timing retard results
Took the car to the 1/8 mile last night. I've listed the weather/track conditions below. I was to hot/lazy to do any back to back comparisons so I just left the timing retard hooked up (never put it back to original timing). The car appears to be making a bunch more power now, as the tire spin is back. With the weather being as bad as it was I figure it gave me a solid tenth or so. Most of the guys I race with were off as much as 2-3 tenths! I was off my best (at this track) by .05. I ran a 7.06 with roughly 1000' (DA) better air and slightly cooler. I don't know what the correction factor is but I'm guessing it would be good for atleast a tenth or two. I'll try do my back to back testing when it cools down a little.
Thanks.
Track elevation: 600'
Density Alt: 2600' !!!!!!
Temp. 87F (80% Hum.)
Best et 7.11
MPH 95.98
Best 60' 1.55
post #10 of 18 (permalink) Old 08-01-2007, 09:27 AM
dfree383
Guest
Posts: n/a
Quoted: Post(s)
Jim,
What parts did you use?
post #11 of 18 (permalink) Old 08-03-2007, 12:03 PM Thread Starter
Originally Posted by dfree383
Jim,
Dave,
For the timing retard, I used the MSD 8980 box with a 4 degree chip. I ran the purple/green (I think) wires that come off the box inside the car and hooked it to a nitrous switch. I bolted an NOS mounting bracket to the back of the shifter so when I shift into high gear it activates the switch. If you run this type of setup you have to run a switch that has the normally open and normally closed tabs on it. Got one from Jegs for $8.00. One wire from the box needs to be hooked to the normally closed tab so when the switch is activated it will interupt the ground path and activate the retard. I'll try and get a picture of the switch mounted to the shifter. I hope this wasn't too confusing. Let me know if you have any questions. Later....
post #12 of 18 (permalink) Old 08-03-2007, 12:13 PM
dfree383
Guest
Posts: n/a
Quoted: Post(s)
I think I understand, your just using a switch when you hit hi gear to retard it.
post #13 of 18 (permalink) Old 08-03-2007, 04:32 PM Thread Starter
timing retard
Exactly. The shifter handle contacts the switch in Third gear only. I was able to take my timing from 36 to 39 degrees (in first & second) and then kick it back to 35 total in third. Like I said before the difference in power is very noticeable. The plugs have not shown any sign of detonation and it pulls much quicker to the shift light. Next time I get it to the 1/4, I plan on doing my back to back testing to see exactly what the gain/loss will be. If you have any suggestions let me know. Thanks!!!
post #14 of 18 (permalink) Old 08-03-2007, 05:28 PM
richter69's Avatar
I did this same thing years back on the 306 car, we pulled it back like 2* on every gearchnge, 2 total.
Made a small diff on et, but the box went wacky and was retarding when it was not supposed to, so we scrapped the idea.
I just used two switches mounted on a plate and the shifter would trip them with each shift.
69 Grande'
P51 headed 563
3070#'s
5.15 @ 134.89
richter69 is offline
post #15 of 18 (permalink) Old 08-03-2007, 05:49 PM
dfree383
Guest
Posts: n/a
Quoted: Post(s)
What about using a timer? Like a NO2 controler or something?
