Gimme some vapor lock fixes - 460 Ford Forum
post #1 of 10 (permalink) Old 10-07-2007, 08:20 AM Thread Starter
I added a PVC 1/4" carb spacer and wrapped the hardline with rubber line.
No time to test drive today but Ill add stuff if you guys have anymore EZ ideas.
My heat riser is not blocked off (evertime I try to block one off I have problems with il leaks) and I am keeping my stock airlid
Phil is offline
post #2 of 10 (permalink) Old 10-07-2007, 08:25 AM
An electric fuel pump will do the trick. It has for me in the past! JMHO
Wes Adams FORD428CJ
Built Ford Tuff With Good Ford Stuff
03 F-250 Crew Cab 4x4 6.0 and 35's
64 Falcon 428FE
55 FORD Truck 4-link Rides on air with 428FE
2000 Yamaha V-MAX VMOA#4277
2000 Yamaha 700 Mountain Max
2001 Polaris 600 Edge X
2001 Polaris 500 SP
Ford428CJ is offline
post #3 of 10 (permalink) Old 10-07-2007, 09:05 AM
cletus66's Avatar
Quoted: 8 Post(s)
I had a problem..
I had a problem when my fuel line in the back was too close to the exhaust. Drove on the street fine for months with no problems, and the first time I took it to the track , it crapped out on the starting line because of idling so long in the staging lanes. ops: Rerouted the line, and never had another problem with that one. That was a stock mechanical pump and about 15 years ago.
cletus66 is offline
post #4 of 10 (permalink) Old 10-07-2007, 03:45 PM
Get an electric fuel pump and a regulator near the carb. Put the fuel pump near the tank.
Problem will be solved.
FE_rex is offline
post #5 of 10 (permalink) Old 10-09-2007, 09:49 PM
Ummm, I think I was having this problem at the track yesterday also, and I have the electric pump near the tank(prostar500) to the regulator mounted off the carb studs. Could it be not running enough pressure into the carb?? The cheap mechanical gauge says 3psi but the electric autometer says 6 3/4psi. I have been having this problem for quite some time, and havent been able to figure out why it does it, until somebody asked if it was vaporlock yesterday :shock:
Fordguy545 is offline
post #6 of 10 (permalink) Old 10-09-2007, 09:58 PM
Greg_P's Avatar
Re: Gimme some vapor lock fixes
What's your fuel pressure doing? Be sure you have a problem before you implement a "solution".
Greg
In Limbo at all times
Greg_P is offline
post #7 of 10 (permalink) Old 10-11-2007, 07:59 AM
Greg is heading you in the correct direction. "Vapor lock" exist when the fuel in the fuel line is heated to a point that it creates a pressure greater than the supply pressure. As others have mentioned, check fuel line routing and fuel pressure.
Can you say, "fuel stall".
Dave.
Masters Degree in Perverted Idiocy.
LivermoreDave is offline
post #8 of 10 (permalink) Old 10-11-2007, 10:09 AM
kim
Unless the mechanical pump is failing to a point where the engine vacume is pulling the fuel faster than the pump can supply it, its not vapor lock.
Could simply be lack of delivery. (ie not enough pump) and the engine is going lean.
Vapor lock, is a function of diaphram (mechanical) pumps sucking the fuel from a fuel tank, if the fuel is too warm, from either atmospheric temps, or close proximity to a heat source (brakes or exhaust) when the pump tries to "suck" the fuel forward, instead of flowing as a liquid it flashes to vapors, and of course we cant/don't want to meter vapor gas, the carbs need liquid flow. So long as you continue to attempt to "suck" the gas forward, it continues to flash to vapor.
Thats why rear mounted electric pumps were implimented, to prevent vaporlock problems. AS you apply pressure from the source, fuel is compressed versus sucked, and is unlikly (wont) flash to vapor in the fuel line.
kim is offline
post #9 of 10 (permalink) Old 10-11-2007, 12:26 PM
jrocco's Avatar
I have a friend with a 70 Mach 1 and on our last cruise he had similar problems. Car would run and then not start after sitting for 15 munites or so. Also he noticed some performance problems while running.
Fuel Filter was clear. Blew back the line to the tank. So we thought Vapor Lock ????? We started it on ether and continued on.
Later that day it happened again so I pulled the fuel line from the carb and stuck it in a bottle while cranking the engine. Hardly any fuel after several cranks.
So we replaced the fuel pump and it ran fine from then on. My guess is that the valves in the pump were failing.
Jerry Tomasello
70 Torino 429
Club Moderator - the Ford Torino Club
http://autos.groups.yahoo.com/group/TheFordTorinoClub/
jrocco is offline
post #10 of 10 (permalink) Old 10-13-2007, 04:02 AM
Took my 71 f100 460 To Atlanta from Charlotte to pick up a car last year. While on the interstate the truck would start acting like it was running out of gas. Start bucking and backfiring until it would finally quit. I could crack the gas line open a bit and hear pressure coming out before the fuel would. It would run fine for about 15 miles before starting all over again. The clear filter would show almost no gas until I opened the fuel line and let the pressure out then it would fill up again.
I had a long way to go so I stopped and put on an electric pump right at the bottom of the tank. It was made for a carb so the pressure was supposed to be right. I could then go about twice as far before it would act up again.
I left the open air filter off the carb and it would go even further before acting up.
I never had any problems before but usually stay alot closer to home.
Later I added a phenolic spacer under the carb. Closed off the heat port under the carb and re-routed my fuel line.
It doesn't do it anymore unless it is very hot out and I am idleing a very long time.
Is this vapor lock, fuel percolation in the carb or are they the same thing.
I once made my own Baltic Birtch carb spacer for a 351w and felt like it kept the carb alot cooler. I think I will try that again.,
clint
1971 Ford F100, 460/c6
PS, PDB, Auto, 3.0 gear
cdeal28078 is offline
