Engine Block Weights 460 iron vs. aluminum - 460 Ford Forum
post #1 of 15 (permalink) Old 02-08-2008, 05:38 PM Thread Starter
Gentlemen,
I tried last night searching for the answers to this but could not find anything that clearly answered my questions.
Does anybody know what the weights are for the following engine blocks, bare, with just the main bearing caps:
Ford 460 production block
IDT Eliminator Sportsman block
Ford Aluminum 460 block
Thanks in advance,
Mike Johnson
Michael Johnson is offline
post #2 of 15 (permalink) Old 02-08-2008, 06:24 PM
TopSportsman916's Avatar
My factory block with .080 over bore weighed about 215 lbs. My A460 block before any boring weighed right at 300 lbs. My 11.2" Roberts Design(A96) aluminum block with no boring ( has 4.48" sleeves) weighs 186 lbs. Hope this helps you.
Chris
VPRC 1998 Mustang
557 CJ :1.15 60', 5.32@129.58 mph @ 2600lbs
665 C&C Hemi : To Be Determined
TopSportsman916 is offline
post #3 of 15 (permalink) Old 02-08-2008, 06:47 PM Thread Starter
Chris,
Many, many thanks.
I'm somewhat surprised that there is only a 30 lb or so weight diff between the factory iron block and the aluminum block.
Mike Johnson
post #4 of 15 (permalink) Old 02-08-2008, 06:50 PM
IDT Eliminator is about 275 lbs.
Outlaw5.0 is offline
post #5 of 15 (permalink) Old 02-08-2008, 06:59 PM
Quoted: 38 Post(s)
Boring an A460 block to 4.600" removes about 50 pounds .
B F Evans Race Parts
270-278-2376
Lem Evans is offline
post #6 of 15 (permalink) Old 02-08-2008, 07:04 PM
Originally Posted by Michael Johnson
Chris,
Many, many thanks.
Mike Johnson
Mike, you have to fealize the factory block is 10.3" deck & the aluminum block has an 11.2" deck height. You have added .900 to the deck height.
Chris
VPRC 1998 Mustang
post #7 of 15 (permalink) Old 02-08-2008, 08:16 PM Thread Starter
Chris,
Oops, I should have qualified that I was looking for 10.3 deck height block weights.
Lem,
Thanks for the info about A460 blocks, so a machined A460 block would weigh in at around 250 lbs?
Anyone know if the IDT block weight at 275 is before or after machining?
Thanks,
Mike Johnson
post #8 of 15 (permalink) Old 02-08-2008, 10:21 PM
Mike, I would guess a 10.3" aluminum block would be in the 140-150 lb range. Carroll Carter said it was about a 150 lb weight savings. Sorry that I forgot to post that earlier. ops: Especially since you were looking for stock deck heights.
Chris
VPRC 1998 Mustang
post #9 of 15 (permalink) Old 02-08-2008, 11:28 PM
Chris,
Lem,
Thanks,
Mike Johnson
Before. They are about 250lbs at 4.600 bore if my source is correct.
post #10 of 15 (permalink) Old 02-08-2008, 11:43 PM
Quoted: 38 Post(s)
The A460 blocks come with a 4.340" bore..... -.020" . So , one could see that there would be a great reduction of wt. @ 4.600 from the as delivered bore . I am the the source of this info
270-278-2376
post #11 of 15 (permalink) Old 02-09-2008, 12:22 AM
Q: whats the difference in pricing of the 10.3 A460 iron VS Aluminum block?
ICBOSS is offline
post #12 of 15 (permalink) Old 02-09-2008, 12:57 AM
Frank Merkl's Avatar
Quoted: 8 Post(s)
about $4000
Frank
Frank Merkl is offline
post #13 of 15 (permalink) Old 02-09-2008, 07:55 AM
A460 per Lem Evan's website = $2095
10.3"R.D. Aluminum per C&C = $5570
For a difference of = $ 3475
So you can actually buy two A460 blocks for less than an aluminum. A460 blocks are a good deal. How much are the top of the line IDT blocks? Aren't they about $2800-3000?
Chris
VPRC 1998 Mustang
post #14 of 15 (permalink) Old 02-16-2008, 06:24 PM Thread Starter
Thanks to everyone
I just wanted to thank everyone for their responses, I had some computer problems and was unable to respond earlier.
Mike Johnson
post #15 of 15 (permalink) Old 02-16-2008, 07:58 PM
Re: Thanks to everyone
Mike Johnson
i think my block from c&c weighed about 150lbs compared to about 275-280 for an iron deal. my small block rdi aluminum 9.5 block only weighed about 80-90lbs.
SSO2028 is offline
