460 Compression Ratio - 460 Ford Forum
post #1 of 25 (permalink) Old 05-21-2009, 12:13 PM Thread Starter
Would anyone know the approximate compression of a 460 using a replacement 460 pistons (1973-1979) with a set of DOVE heads? The engine now has D3VE heads and is probably in the range of 7.5:1--8.0:1 compression. I figure losing almost 20cc in the combustion chamber should maybe bump compression into the 9.0:1+ range. Any thoughts?
bbfguy1 is offline
post #2 of 25 (permalink) Old 05-21-2009, 12:22 PM
RJP
Rebuilder pistons with the 22 cc "bathtub" dish, a zero deck [10.295-10.300"] and the D0VE-C heads 75-77 cc should yield about 9.7-9.8 to 1 C/R
RJP is offline
post #3 of 25 (permalink) Old 05-21-2009, 02:32 PM
Quoted: 143 Post(s)
That is the key !!! 22 cc dish pistons at ZERO deck.
The typical builder piston has a 1.752" compression height. These pistons would require a deck height of 10.282". In an uncut early block that would net .018" below deck. Darned near .040" below deck in a late 10.322" deck height block.
My calc says:
9.91 to 1 at 0 deck with a 72 cc chamber
9.66 to 1 at 0 deck with 75 cc chamber
9.5 to 1 at 0 deck with a 77 cc chamber
9.15 to 1 at .018" below deck on early block
8.8 to 1 at .040 below deck in a later block.
We have had to deck the later blocks some .035" or a tick more to get 0 deck with the short compression height builder and sealed power pistons.
I have noted early 460's that were unopened and they are typically .010" below deck and a small dish. The later engines were .030" or better with a much larger piston dish OEM.
When I started checking piston compression heights, dish volumes and such I was shocked at the miserable oem c/r in the later engines.
http://R-H-P.biz
post #4 of 25 (permalink) Old 07-14-2009, 12:03 AM
Send a message via AIM to swamperspecial
so how do you know what the dish of the pistons are if it is given in inches. For example, summit sells a piston with .240 oblong recess deep. is this a 22cc dish?
1979 F150 4X4. D60 rear, D44 front with 4.10s. 35 inch MT. C6 with E40D wide ratio kit. 220HP 306ftlbs to the ground with a 400M....while i'm building a real big block
swamperspecial is offline
post #5 of 25 (permalink) Old 07-14-2009, 12:22 PM
Quoted: 143 Post(s)
Sounds like it. Can you link to a pic of what you are referring to???
http://R-H-P.biz
post #6 of 25 (permalink) Old 07-14-2009, 12:25 PM
Chuck Stevens's Avatar
My philosophy has been: if "they" won't give you the REAL numbers on the product they are trying to sell to you...I'm not interested in buying it, no matter how "good" the deal is.
Chuck Stevens is offline
post #7 of 25 (permalink) Old 07-14-2009, 04:18 PM
Send a message via AIM to OldRedFord
I am assuming they are:
http://www.summitracing.com/parts/STL-H418P/
Now this got me to wondering about my combo again.
With stock chamber size D3's and stock deck height (D1ve block)
http://www.summitracing.com/parts/UEM-KB137-STD/
Would those get me to 10 to 1 c/r or so? Not my final piston choice or source, just wonder.
2002 Ford Ranger 4x4
1972 Ford F100 Sport Custom
460, C6, 9" rear, lwb
OldRedFord is offline
post #8 of 25 (permalink) Old 07-14-2009, 06:34 PM
Quoted: 143 Post(s)
Your cam choice and intended use are the criteria used to determine appropriate c/r for the application. Which fuel you wish to use is of course a factor also. Do the above first before choosing a piston combo and an arbitrary static c/r figure.
The answer to your question. 22 cc dish at 0 deck with large chamber d3's wil be close to 10 to 1.
http://R-H-P.biz
post #9 of 25 (permalink) Old 07-14-2009, 06:44 PM
Cam...Crane Cam duration 288/292 lift 522/530. This is the engine for my F100. Street/strip vehicle. Cam card lists 9.5-11.0 c/r. Pump gas would be nice.
post #10 of 25 (permalink) Old 07-14-2009, 07:12 PM
Quoted: 143 Post(s)
Iron heads / pump premium...
10 to 1 is ok with tight quench at 466 inches.
http://R-H-P.biz
post #11 of 25 (permalink) Old 07-14-2009, 07:35 PM
kjett's Avatar
Quoted: 14 Post(s)
So what would compression be on a D1 block with a set of SRP flat tops be at zero deck with a set of D3's that have been shaved .030? I was figuring around 9.5 or 10-1, but if a 22cc dish is there, would this get me closer to 11-1?
kjett is offline
post #12 of 25 (permalink) Old 07-14-2009, 07:46 PM
DJOHAGIN's Avatar
With 90cc chambers, you would have around 10.2 to 1.
Dave
DJOHAGIN is offline
post #13 of 25 (permalink) Old 07-14-2009, 07:53 PM
kjett's Avatar
Quoted: 14 Post(s)
so from a 22cc dish to a flat top on a zero deck block with D3's only gains .2 in compression? Seems almost a waste of my time to put them in, I figured it would be better than that.
kjett is offline
post #14 of 25 (permalink) Old 07-14-2009, 09:53 PM
so, what compression ratio would those pistons create with a set of dove heads?
post #15 of 25 (permalink) Old 07-14-2009, 10:01 PM
kjett's Avatar
Quoted: 14 Post(s)
They are supposedly 11:1 on 72cc heads, so figure from there.
kjett is offline
