Ignition/Timing questions - 460 Ford Forum
post #1 of 11 (permalink) Old 07-29-2009, 11:20 PM Thread Starter
Sorry if these are dumb questions, but this is my first in depth project and I'm a beginner working with motors. I have the following:
Ford 460 block bored .060 over with H418p pistons. Comp 34-331-4 (280 H) came with Comp Magnum roller tip rockers. Using Edelbrock performer heads, Edelbrock performer RPM intake, Holley 750 vacuum secondary carb. Using a C-6 with a 2000 stall converter.
1. I'm confused about timing. The timing marks on the damper are not consistent with the marks shown in the Chiltons manual. The timing marks are 0-60. I need to run at least at 32 to keep it running. What would be proper starting point for timing setting with this damper?
2. I have a MSD stand alone distributor with Blaster II coil. I also have a spring kit for the distributor. Is the stock spring in this distributor the best, or should I start out with one of the other spring sets? I believe they are color coded.
3. Any estimates at the HP I should see if properly tuned?
Thanks again.
hp246 is offline
post #2 of 11 (permalink) Old 07-30-2009, 08:16 AM
Are you using a stock damper or aftermarket?Some dampers are marked for the 10 o-clock position and some 11 o-clock. I always spring my dist. so that they have full advance by 3000rpm.This allows you to start the engine at a lower timing but is usually at full advance by the midway of low gear.
tonyj202b is offline
post #3 of 11 (permalink) Old 07-30-2009, 04:28 PM Thread Starter
Tony,
The machine shop assembled the motor. The part number listed is 80008 Harmonic Balancer. I believe it is a Professional Products Balancer.
hp246 is offline
post #4 of 11 (permalink) Old 07-30-2009, 06:52 PM
Is your pointer at 10 o-clock? I am goimg to assume it is because their web site states that in the 1/4 key way on a stock crank tdc should be at 10 O.With that being said are you having problems keeping it idleing,won't rev up or what exactly?Could be carb adjustment not timing issue.
post #5 of 11 (permalink) Old 07-30-2009, 09:55 PM Thread Starter
Tony,
What I'm trying to do is set a basic timing so I can start tuning from there. The pointer is set in the block. The damper shows a 0-60 marking on it. Everything I've read says timeing should be set from 10-14 degrees btdc. I currently have the timing set a 36 using the markings on the damper. If' I.m reading the marking correctly on the damper, that would correspond to 1 to 60 btdc. Is that correct? If I tried moving the timing to 14 degrees per the markings on the damper, then the engine would not run. So, I am thinking that the markings on the damper are actually for the crank, and that tiing number should be something different than the spec in the manual for ignition timing.
I've seen references to crank timing and ignition timing, but never seen a spec for crank timing.
Sorry, really kinda confused here.
hp246 is offline
post #6 of 11 (permalink) Old 07-30-2009, 10:10 PM
falcon8r's Avatar
If you can index the timing mark and use a timing light with an advance function, you are good. Remove the #1 plug and find tdc. Average the reading where the piston just starts to move down in both directions. The middle of these should be TDC on your balancer where your pointer is. If that is good, a timing light with adjustment will run off the tdc mark on the balancer and you could dial in 36deg total or such. With the light springs in the Msd this should be close. The msd springs installed stock are stiff and allow full adv. very high in the rpm. Tres...
533 powered 1961 falcon , my car. Hot Rods and Tuners ....
falcon8r is offline
post #7 of 11 (permalink) Old 07-30-2009, 10:15 PM Thread Starter
hp246 is offline
post #8 of 11 (permalink) Old 07-30-2009, 10:35 PM
As Falcon8r said i would remove the #1 plug insert a screw driver and bring the piston up to tdc and see where the balancer is at and then go from there.The marks on the balancer is ignition timing.Only crank timing that is timing crank with cam via timing chain and gears.Its possible your balancer just is not right with your pointer.As said bring it to tdc and see where your pointer is at (example its pointing at 14) then you know 14 is actually 0 and 26 would then be 12 and so on.Or you could put a timing tape on it.
post #9 of 11 (permalink) Old 07-30-2009, 11:05 PM Thread Starter
Thanks guys, that makes sense.
hp246 is offline
post #10 of 11 (permalink) Old 07-30-2009, 11:07 PM Thread Starter
Falcon,
From reading your post, you are saying to swap out the MSD springs to the lightest weight set?
hp246 is offline
post #11 of 11 (permalink) Old 07-31-2009, 11:32 AM
falcon8r's Avatar
Originally Posted by hp246 View Post
Falcon,
Yes . You will get all the timing in at maybe 3000 rpm intstad of 5500 rpm. So if the engine is running at 3500 rpm, the timing would not go up if you raised the rpm from there. You will find that the msd paperwork that was with the dizzy states this. This may allow a lower initial setting which may help with starting sometime. Tres...
falcon8r is offline
