'73-'87 stock compression - 460 Ford Forum
post #1 of 10 (permalink) Old 08-24-2009, 10:59 PM Thread Starter
79Bird466's Avatar
I punched the numbers into the C/R calc and got about 7.85:1. Is that about right? I have always seen the ratio listed as 8:1...is that just a rounded figure? This is for a 10.322 deck with stock D3VE (95cc) heads, 22cc dish piston and a .041 head gasket. Do all these numbers look accurate for a stock smogger?
'79 Thunderbird
466CI/C6/3.25 Traction Lok 9" Rear
D1VE block, D3VE heads, C8SE Intake & Cam, Carter AFB 625cfm carb, Duraspark II, Police oil pump, EFI timing set, 8.3:1 CR, etc...
79Bird466 is offline
post #2 of 10 (permalink) Old 08-24-2009, 11:05 PM
Administrator
Cale Aronson's Avatar
72' was 8.5.1 So I think it was close....
Cale Aronson - Administrator
Black Magic Clutchs - Aronson Motorsports
Shelby Performance Mountain Motor Pro Stock Mustang
Shop - 660-646-4553 - Cell - 816-390-0852 - Email - cale@BlackMagicClutches.com
WWW.BLACKMAGICCLUTCHES.COM - WWW.GOFASTQUICK.COM
Jon Kaase Racing Engines - Ford Racing Parts - RAM Clutches - Browell - Trick Titanium - Bohr Racing - PEM Gears - Orme Brothers - Penske Racing Shocks - Innovators West - DJ Safety
Cale Aronson is offline
post #3 of 10 (permalink) Old 08-24-2009, 11:28 PM
Diggindeeper's Avatar
yeah you're likely on the right track. The compression ratio flat sucked in the smogger era for the 460.
Diggindeeper is offline
post #4 of 10 (permalink) Old 08-24-2009, 11:47 PM
Administrator
Scary part is in 71' they were 10.5.1!!!!!!
Sheesh!
post #5 of 10 (permalink) Old 08-24-2009, 11:51 PM Thread Starter
79Bird466's Avatar
Did the '72s use flat tops or did the D2VE heads have smaller chambers? or neither?
'79 Thunderbird
post #6 of 10 (permalink) Old 08-24-2009, 11:54 PM
Paul Kane's Avatar
Quoted: 14 Post(s)
Actual real world comrpession ratio for the 1973-1986 engines is about 7.7:1, and possibly less depending on actual cylinder block deck height (which varies from block to block by several thou) and acutal combustion chamber volume (which also varies).
Paul
High Flow Dynamics
Paul Kane is offline
post #7 of 10 (permalink) Old 08-25-2009, 12:10 AM
Administrator
Paul is right.... looking at my books that is true. The 73's were about 7.5.1 in all actuallity.
Here.... this might help a little...
post #8 of 10 (permalink) Old 08-25-2009, 12:23 AM Thread Starter
79Bird466's Avatar
I think the calculator is a bit off. I just entered the specs given from that book for a '72 460 and came up with 8.06:1. I even used the high end of the chamber size range (92.9cc) ...I'm assuming they used the same pistons as '73-'87 (-22cc)
'79 Thunderbird
post #9 of 10 (permalink) Old 08-25-2009, 12:35 AM
Paul Kane's Avatar
Quoted: 14 Post(s)
1973-1986 heads have a chamber volume of closer to 97ccs typical, and the OEM 1973-1987 dished pistons are closer to 24cc total dish volume. Plug those numbers in and see what happens.
Paul
High Flow Dynamics
post #10 of 10 (permalink) Old 08-25-2009, 12:49 AM Thread Starter
79Bird466's Avatar
Paul
I came up with 7.75:1 with a piston-to-deck clearance of .032 (listed in the book)
7.66:1 using .040 as a PTD clearance, which is what I have been told it is closer to.
'79 Thunderbird
