523 "poor boy stroker" - 460 Ford Forum
post #1 of 31 (permalink) Old 09-14-2009, 04:21 PM Thread Starter
I have a chance to buy the pistons and rods for cheap, but have never heard of this before is it a good combo or is their problems with it? The combo has custom Venolia pistons on 300 6 cyl rods with arp bolts. The guy that owns them said to get a stock crank off set ground to 4.25 stroke puch a block +80 and there it is. He ran these with D0VE and D0OE heads.
tiger is offline
post #2 of 31 (permalink) Old 09-14-2009, 05:20 PM
Quoted: 48 Post(s)
I always thought they used a 240 rod in that combo and I think that they are a different length than 300 rods. I've heard that as long as the rpm/power level is moderate that it works fine and doesn't break. With that said today it's probably less expensive if you're paying for machine work to just go with a 521 using a Scat cast crank, Scat I beam rods and a piston from Probe. This combo is easy to build and balance and it doesn't cost much because everything is an off the shelf part of modest cost.
Dave McLain
McLain's Automotive
DaveMcLain is offline
post #3 of 31 (permalink) Old 09-14-2009, 06:24 PM
CarsByCarl's Avatar
Quoted: 87 Post(s)
I've built them that way. A crank should be $350 or less so if the deal is good enough on the rods/pistons, it might be worth doing.
CarsByCarl is offline
post #4 of 31 (permalink) Old 09-14-2009, 09:23 PM
DJOHAGIN's Avatar
LOL.
If you know what you're doing, it's worth it. In your case, Tiger, since you don't, don't do it.
IMHO,
Dave
DJOHAGIN is offline
post #5 of 31 (permalink) Old 09-14-2009, 09:45 PM Thread Starter
what size are the 6 cylinder rod journals? If I buy the crank and have the block sonic checked before boring that far and then balance the thing is their anything else I should look to do?
tiger is offline
post #6 of 31 (permalink) Old 09-14-2009, 10:34 PM
mudbogtom's Avatar
Originally Posted by DJOHAGIN View Post
LOL.
IMHO,
Dave
Sometimes one learns by trying. Education isn't cheap, but having the knowledge is priceless.
Tom
mudbogtom is offline
post #7 of 31 (permalink) Old 09-14-2009, 11:51 PM
When using the Scat stroker crank, You still have to purchase aftermarket pistons, which are probably least expensive when purchasing as a kit... correct? From what I've found, if you get a good block to start out with, The least expensive route from there for building up the bottom end to over 500ci is to purchase one of the stroker kits (I beleive I've seen them starting at around $1,300).... Anyone know of any other less expensive routes for decent quality budget stroker?
74d_Ranger is offline
post #8 of 31 (permalink) Old 09-15-2009, 12:43 PM Thread Starter
Thank you for the info Carl. It was a big help to me.
tiger is offline
post #9 of 31 (permalink) Old 09-15-2009, 02:31 PM Thread Starter
Maybe somebody can answere this question for me. Since I can almost buy a new 4.5 crank for what it cost to turn a crank to the size I need for this poor boy stroker. Can I just stick a 4.5 crank in a block with the factory length 6.605 rods and .030 over factory style flattop pistons and get over 530 ci? Is this right?
tiger is offline
post #10 of 31 (permalink) Old 09-15-2009, 04:26 PM
No.
A factory piston and a factory rod with a bunch more stroke will not work. The piston would come out of the top of the block. You will need a shorter rod, a piston with a higher pin height or both. Buy a kit. Being to cheap on all this will not turn out so well. Run er stock or spend some cash money.
93 F150 4x4 Big Block Ford Truck!
Fordtrucks is offline
post #11 of 31 (permalink) Old 09-15-2009, 04:38 PM
Paul Kane's Avatar
Quoted: 17 Post(s)
Originally Posted by Fordtrucks View Post
No.
The common cookie-cutter stroker kits available today almost always use connecting rods that are longer than the 429/460 OEM rod, not shorter.
To answer tiger's most recent question more appropriately, a 4.5 stroke crankshaft will need the correct combination of rod and piston in order to be fit for the application. And for the store-bought parts such as the 4.5 crank, usually a 6.700" or 6.800" length rod is what is typically used (OEM rod is 6.605"), depending on piston pin location.
Tiger, just because the 4.5 stroke crankshaft is more-or-less priced the same as lesser stroked cranks, this does not necessarily mean that the engine build will cost the same amount as a smaller displacement engine. Do some research/plan ahead.
Paul
High Flow Dynamics
Paul Kane is offline
post #12 of 31 (permalink) Old 09-15-2009, 04:40 PM Thread Starter
Thanks guys.
tiger is offline
post #13 of 31 (permalink) Old 09-15-2009, 04:50 PM
I would also be interested in the answer that question.
I might be asking for the impossible, but I would like to be able to get over 500 cubes for under a grand (Crank, Pistons, rings...). assuming I'm starting with a 460 block & internals bored clean to .030 or .040.
post #14 of 31 (permalink) Old 09-15-2009, 05:12 PM
THATS EXACTLY WHAT ME DID. I puts the rod in a vice and squeezed them oval until they fit the crank. Then when the piston stucks out of the bore, I tooks me grinder and ground that sucker until it was flush with the block.
It makes a little noise when it runs, but it was chep. It doen't make very much power. Can someones tell me hows to make more. Me have D2VE heads on it.
THANKS THIS MAKES ME HAPPY
GomerPyle is offline
post #15 of 31 (permalink) Old 09-15-2009, 06:46 PM
1Bad65's Avatar
lmao...that was the laugh today for me
1Bad65 is offline
