Valve relief cutter. - 460 Ford Forum
post #1 of 11 (permalink) Old 03-29-2010, 03:23 PM Thread Starter
Does anyone have a cutter that uses the valveguide as a guide that I could rent. One like Kaase sells. Thanks
hookedonpullin is offline
post #2 of 11 (permalink) Old 03-29-2010, 08:39 PM
PHIL1206's Avatar
what size cutter you need
we're all friends till they wave the green flag
PHIL1206 is offline
post #3 of 11 (permalink) Old 03-29-2010, 09:04 PM Thread Starter
Ah yes, that would be helpful to know huh. It's for a 2.25 valve so, 2.35 dia. cutter.
post #4 of 11 (permalink) Old 03-29-2010, 09:34 PM
bruno's Avatar
isky makes the also
http://iskycams.com/cart/index.php?m...=3944&cPath=55
www.429-460.com
"HOME OF THE FASTEST BIG BLOCKS"
bruno is offline
post #5 of 11 (permalink) Old 03-29-2010, 10:20 PM
strokerstang86's Avatar
Lindy tools sell and rents them. He makes them for kaase, he is vary nice and will help you out.
http://www.lindytools.com/
strokerstang86 is offline
post #6 of 11 (permalink) Old 03-29-2010, 10:40 PM Thread Starter
I will give them a call, thanks!
post #7 of 11 (permalink) Old 03-29-2010, 11:15 PM
57custom's Avatar
Smile I seem to remember
that someone used an old valve and brazed a small piece of carbide to it and then had a homemade cutter that worked quite well. I think I saw it in Hot Rod magazine many years ago. I know it stuck in my mind for some reason or other.
63 Fairlane 500 tudor sedan 10.44/131 so far thru the mufflers. 10.29 with open exhaust. Update 10.20 at 132 open axhaust
57custom is offline
post #8 of 11 (permalink) Old 03-30-2010, 11:25 AM
PHIL1206's Avatar
I think i got one that size your welcome to use it i'll look when i get home.
PHIL1206 is offline
post #9 of 11 (permalink) Old 03-30-2010, 11:57 AM
Wink
I've posted this before, have used it and it really works well, plus it is inexpensive and a lot more 'forgiving' than the steel cutters.. I got the idea off of FordMuscle.com...tech section.
Take an oversize valve and glue a round cut piece of 80 grit cloth back sand paper to the valve. Cut it so that about 1/16 of an inch sticks out around the valve. I used self stick 80 grit as it is easier to remove. It took me 2 pieces per valve to get .064. I cut all of the pieces first.
Tape around the piston to prevent any dust from getting between the piston and the cylinder. I used two thicknesses of masking tape, lengths about 1 1/2 inches to get around the piston. I installed my head and tightened it down, no need to torque it. Stick the working end of a shop vac hose in the exhaust port to suck out the dust.
I made a piece to go over the valve stem to keep the cut uniform for each relief. Drilled and taped it for a small set screw. Put the valve in the head in the cylinder to be cut with the stop holding the valve against the head. After I tightened the head I loosened the set screw on the stop and pushed the valve down to seat in the valve relief. Loosened the set screw and set my distance with a feeler guage between the valve guide and the bottom of the stop and tightened the set screw. It's kind of hard to keep pressure on the valve ,set the distance with the feeler guage , then tighten the set screw. Another hand or two would be nice, but I did it so you probably can also. Unless you can find someone to help. Remember, don't push on the drill too hard.
I did take the head off quite a bit to check the depth of the cut and to check the sandpaper. It took me a while to do, but it was cheap and effective. Plus I got a lot of excersize from taking the heads on and off.
Good luck with any method you use!
'64 Galaxie 500 XL 499/C6, '06 Mustang GT
GT300TD is offline
post #10 of 11 (permalink) Old 03-30-2010, 02:44 PM
138
138's Avatar
138 is offline
post #11 of 11 (permalink) Old 03-30-2010, 08:44 PM
fastbarry's Avatar
i have one that i built out of an old intake valve. i used it to notch a set of stock truck pistons for a set of cj heads in a pinch for my boat last year. it is an old cj 2.25 valve with a piece of carbide brazed on it for a cutter. i would let you borrow it. pm me if interested.
barry
Strong Arm Customs
custom welding and machine
big block ford addicts anonymous member since 2001
http://i95.photobucket.com/albums/l1...barry/01-1.jpg
fastbarry is offline
