Valve cover torque lbs - 460 Ford Forum
post #1 of 8 (permalink) Old 04-08-2010, 06:40 PM Thread Starter
I got my engine with a set of old Holley cast aluminum valve covers. Stock steel covers use 10 lbs of torque, what would be right for the cast aluminum? I am using Felpro 3/16" steel core cork-lam gaskets.
Last thing I want to do is break/crack the covers!!!!
donwhis is offline
post #2 of 8 (permalink) Old 04-08-2010, 09:37 PM
Send a message via Yahoo to johnnywalker
is that 10 inch lbs or 10 foot lbs ? that little bolt will only take so much torque before it brakes !! so make sure .
johnnywalker is offline
post #3 of 8 (permalink) Old 04-09-2010, 03:23 AM
Here is what I like to do...........
Coat the valve cover side with aviation gaskett sealer,coat the valve cover with aviation sealant.
Then stick the gaskett to the valve cover..............then depending on if this is track engine or 100,000 mile street engine....if a track engine just lightly coat the head side of the gaskett with silicone sealer........possibly no silicone depending on how often the valve cover has to come off................if it is a street engine with a hydraulic cam that needs no valve adjustment I will put aviation sealant on the head side also.
Then snug the bolts down at about half the torque you will finally use...let it stand overnight ,then fully tighten the bolts down.....I have no idea what the actuall torque spec is for the valve cover...........I just use a 1/4 inch drive ratchet and tighten them down good and snug.......it is something you develope a feel for as to how tight ,then I also use blue loctite on the bolts and clean the threads really well first ,I usually use brake clean for the bolts and use a q-tip soaked in brake clean for the bolt holes.
Some would say that it overkill to do it this way ,but I very seldom have leaks and they stay put when installed in this manner.
I would think you would have to really go pretty tight to break the valve covers or have mushy thick gasketts to break the valve cover ears off from tightening them.........I also like to use the metal reinforced rubber gasketts ,but I am sure the reinforced cork will work fine also.
I did a quick search and 4 to 7 ft pounds seems like the normal recomendation for most of them.
I think you would be safe with 7 to 10 ft lbs considering your gaskett choice....but I would feel it out and if that seems too tight STOP.....
In my mind it would be better to have them too lose at first and have to tighten them ,rather than stripping/breaking a bolt off or crushing the gaskett.
Well thats my 2 bits anyway..........hopefully someone will give you the correct torque spec soon.
shawnlee is offline
post #4 of 8 (permalink) Old 04-09-2010, 03:19 PM Thread Starter
Wink
Thanks for the help. I used 7 ft lbs and had to retighten after they sat for a few hours. Finally got into Holley tech support but they didn't have any torque specs for their old covers. So, I will go with this and check them again after the engine has been run and warmed up.
donwhis is offline
post #5 of 8 (permalink) Old 04-09-2010, 09:03 PM
White Lightning's Avatar
Quoted: 44 Post(s)
1/4" bolt.....7 Ft lbs...about what you can turn with a screwdriver handle.
White Lightning is offline
post #6 of 8 (permalink) Old 04-10-2010, 01:23 AM
95lightiningguy's Avatar
Send a message via Yahoo to 95lightiningguy
I always tighten them down a nut driver as hard as I can and never had a leak nor have I ever broke anything.
89 F150 351w powered
95 F150 300 I6 5 speed soon to be 460 powered lightining clone
95lightiningguy is offline
post #7 of 8 (permalink) Old 04-10-2010, 10:32 AM
Quoted: 105 Post(s)
Right out of a Chiltons manual - "Tighten till fully seated, not to distort the gasket".
I'm gonna make the guess that the GASKET material and strength will determine the torque,,,
post #8 of 8 (permalink) Old 04-10-2010, 10:59 AM
Quoted: 44 Post(s)
X2
