ECU Calibration Specs - 460 Ford Forum
post #1 of 3 (permalink) Old 12-24-2010, 10:29 AM Thread Starter
Danny Cabral's Avatar
Does anyone have the EFI 460 ECU calibration specs? I'm specifically looking for the stock cranking fuel values at different temperatures.
May God's Grace Bless You
Danny Cabral is offline
post #2 of 3 (permalink) Old 12-24-2010, 08:43 PM
Which ECU Catch Code?
mjp_t98 is offline
post #3 of 3 (permalink) Old 12-25-2010, 06:26 AM Thread Starter
I don't have an ECU catch code because I have an aftermarket EFI system (Holley Dominator EFI). I finished tuning the cold cranking fuel for good starting performance and am curious how the OEM values compare to my engine requirements. Any 460 (7.5L) ECU should suffice.
Gear in this thread - Powered by O'Reilly Auto Parts
