Finally!!! FUEL INJECTION MANIFOLDS - 460 Ford Forum
post #1 of 13 (permalink) Old 04-01-2011, 04:08 PM Thread Starter
Fuel Injection Manifold for 88 and older 429 and 460s. called Edelbrock, got part number. Not on web site, but in cataloge......COOOLLLL
Edelbrock 50665 Its a Victor
Summit says will not fit SCJ heads.....
rocky2610D is offline
post #2 of 13 (permalink) Old 04-01-2011, 06:19 PM
Quoted: 212 Post(s)
It is a victor intake in name only as it is based on the Torquer II intake manifold.
http://www.who-sells-it.com/cy/edelb...-fullsize.html
Nice to see them step up as this intake is needed though the aftermarket does have converted victor intakes for multi port injection available.
http://R-H-P.biz
post #3 of 13 (permalink) Old 04-01-2011, 08:55 PM Thread Starter
Darn! Pretty sure I need a Victor...6500 rpm upper range for a 460 may not be enough for a 553.
The Edelbrock EFI is much cheaper than buying a Victor and shipping it off to have it converted for $400 more.
It says it will not fit 429 CJ heads....wonder if that means it will not fit SCJ's?
post #4 of 13 (permalink) Old 04-01-2011, 10:10 PM
Saw that intake advertised six months ago. They still have not added it to their regular site and have to wonder if it actaully is available to buy.
The intake is based on the Torker II and won't match a CJ or SCJ port as the port is taller. Normally you could port the intake to match the CJ port roof, but in this case you cannot because of the fact the injector is located in the port roof. Provided it will seal, which it should unless Edlebrock took material away around the ports you could use the intake on a CJ/SCJ head , but you will be leaving HP on the table. Steve
68xr7cat is offline
post #5 of 13 (permalink) Old 04-01-2011, 11:40 PM
DJOHAGIN's Avatar
Well, if it ain't going to cut it for your 553, it's kind of a moot point complaining about the $400 conversion cost. It will be even better if you the the TFS "Mafia" intake, but that costs more than the Victor, but less porting costs. And yes a 429 CJ and the aluminum Ford SCJ head intake port at the flange are the same.
Dave
DJOHAGIN is offline
post #6 of 13 (permalink) Old 04-01-2011, 11:41 PM
bigblok86ranger's Avatar
Check this out! http://www.cprparts.com/products/airfuel/spyder.html
To my knowledge these are Victor manifolds converted to efi.
Eric Millard
bigblok86gt@yahoo.com
528ci of N/A power
Circle R Racing Engines
Trick Chassis
Beloit,WI 53511
608-313-9197
http://www.trickchassis.com/
bigblok86ranger is offline
post #7 of 13 (permalink) Old 04-02-2011, 09:35 AM Thread Starter
YOU ARE DA MAN!!! I have been looking for something like this for MONTHS!
THANK YOU!!!!VERY MUCH!!!
post #8 of 13 (permalink) Old 04-02-2011, 09:37 AM Thread Starter
Dave
I was not complaining...I was simply stating facts!
post #9 of 13 (permalink) Old 04-02-2011, 01:56 PM
Does anyone know where this manifold can be bought?
If so, please let us all know!
Tom
Wells's law of engine size: If it matters what gear it's in, the engine's too small.
TomW is offline
post #10 of 13 (permalink) Old 04-02-2011, 02:02 PM
Quoted: 212 Post(s)
John Kaase posted test results on a torquer 2 vs a victor both ported and unported.
Here is the thread...
6th update, P-51 heads/ TorkerII intake
http://R-H-P.biz
post #11 of 13 (permalink) Old 04-02-2011, 03:32 PM Thread Starter
Tom
Summit has it!
http://www.summitracing.com/parts/EDL-50665/
post #12 of 13 (permalink) Old 04-02-2011, 05:44 PM
Hmmm, might be just the ticket for a built-for-midrange 521 that won't see the high side of 5500.
Brad
Brad Johnson is offline
post #13 of 13 (permalink) Old 04-02-2011, 06:35 PM
Quoted: 6 Post(s)
i got a fuel injected engine sitting under my hood and the 413 is really diggin in, lol. beach boys.
....now with that intake what other goodies do i need to set it up? thanks bobn
zephyrbob is offline
