Fox Body Swap in Basics - 460 Ford Forum
post #1 of 25 (permalink) Old 09-03-2012, 08:37 PM Thread Starter
If anyone has any input for this thread from previous experience that would be great. Maybe get a sticky out of this since I know we have alot of fox guys here like me. There is not a whole detail to the procedure for the 'easiest' way to install a 460 in a foxbody so from what ive gathered the following are to the get best install:
- Use a full swap kit for full part cooperation
- Install into vehicle with the headers on (being that they are swap headers)
- Install with ~2" k member spacers to tuck under a stock hood ( k member must be from a 5.0 or 2.3)
- Install with the radiator out to reduce damage
- Install with crossmember installed (using stock stang two bolt mount)
- Stock suspension in front will work fine
-Install with trans attached to motor (bellhousing bolts are stupid hard to get at)
- Attach steering linkage AFTER installing the motor.
No matter how ugly I keep making my car, for some reason I keep spending money on it.
overownt is offline
post #2 of 25 (permalink) Old 09-04-2012, 10:18 AM
Foxbigblock's Avatar
Wow. Great idea and topic for sticky. I dunno bout putting all that in at once without mocking up...by stock 5.0 suspension, you mean the stock springs? Stock k member and all with what transmission? Just asking to learn and add.
Oh wait, your k member is modded. Disregard.
1980 Mustang HB
429/C6
1989 Mustang notch
302/C4
Nate
Wide open til ya see God, then BRAKE!!!!
Foxbigblock is offline
post #3 of 25 (permalink) Old 09-04-2012, 11:15 AM
Quoted: 139 Post(s)
I see many different variations here depending on the parts that are used. I put my headers on after I put the motor in. I didn't want to bang them around. I'm also not sure that you could even get the motor in with the radiator in the car. Motor plate cars are going to be even more different of an install.
MrScharfenberger is offline
post #4 of 25 (permalink) Old 09-04-2012, 06:04 PM
bigblok86ranger's Avatar
It would be a great sticky if their weren't so many variables between everyone's install. I haven't really seen a cookie cutter kit from anybody. Some are easier than others though.
Eric Millard
bigblok86gt@yahoo.com
528ci of N/A power
Circle R Racing Engines
Trick Chassis
Beloit,WI 53511
608-313-9197
http://www.trickchassis.com/
bigblok86ranger is offline
post #5 of 25 (permalink) Old 09-04-2012, 06:59 PM
Quoted: 75 Post(s)
Ive done this swap many times with the stock k member,stock 5.0 springs,and 4cly springs w/ a/c to get the front end down quicker
when the car blew the tires off at 60 to 100 feet the 4cly springs were too soft,when it stayed hooked they were great
815-712-8738
Dynoed or Test ran
CLYINDER HEAD PORTING
BOSS 429 is offline
post #6 of 25 (permalink) Old 09-04-2012, 07:10 PM
Quoted: 139 Post(s)
Are you talking about the rear springs or front springs?
I forgot to mention that this is a good idea but there are so many variations that the sticky could be 7 pages long (but who cares). There are a lot of Foxbody guys out there. Maybe the thread ought to focus on the things that definitely have to change to get the 385 series in a Foxbody and then work the different options further down the list.
For instance...
1) Motor mount change
2) Exhaust
3) Transmission
4) Rear end (if converting a 4cyl car).
This way the guys just thinking about doing it will have a decent perspective on everything that has to be changed at a minimum. After that the sky is the limit (ask me how I know...)
post #7 of 25 (permalink) Old 09-04-2012, 08:16 PM
Mustang-Junky's Avatar
Quoted: 6 Post(s)
Motor plate car here. I set the 460 in, left the rear of the motor supported with the hoist then installed the trans. Did the headers afterwards, they don't snake around the steering shaft so the install was easy from below.
I did motor and trans install by myself with out any issues. It was just as easy as dropping in a small block. Spark plug access is as good or better than the 351w in my other mustang. I did however convert to manual brakes before the swap.
Jess
Mustang-Junky is offline
post #8 of 25 (permalink) Old 09-04-2012, 09:34 PM
BigRigTech's Avatar
My tunnel is enlarged at the top so I can access the top two bolts. I have an AJE k-member with coil-over conversion, no blocks between the k-member and body. I put the 460/c6 in as a unit with the hooker headers sitting in the hole. Wiggle the engine, get the header bolts started and then I put on the front motor plate. Stock 5.0 trans crossmember with minor trimming. My headers wrap around my flaming river shaft and I lowered the front of my steering column about 3" in the firewall to get the u-joint angles right. Manual brakes, manual steering. The FRPP swap pan sits about 1/8" off my steering rack.
1987 Mustang GT drag car
472", A429's, 600HP
rollerized C6 with a Merkl t-brake VB
275 Pro drag radials, 9" with 3.89's
Best ET 9.95, best MPH 135
Murphy's law in motion daily
BigRigTech is offline
post #9 of 25 (permalink) Old 09-05-2012, 07:19 AM Thread Starter
This is great, even though we have alot of variation I think its great to have a good reference spot.
Also forgot to add some stuff
-8.8" rears are direct bolt in
-stock manual steering racks require a smaller pinion flange than pw steering, can be purchased on unisteer (long story lol)
-steering column is collapsable, may 'love' to get to move
-trans tunnel may require massage to fit a glide and possibly others
btw my kaufman swap headrs are the biggest pain to install, I'm going to attempt the install with them on first.
other side note for fox guys, I'm making a guide to shoe horn an 70's f350 alum. rad in w/o ac, if it works lol
overownt is offline
post #10 of 25 (permalink) Old 09-05-2012, 08:01 AM
Quoted: 139 Post(s)
Just as a reference... Before I bought my Griffin radiator for my 93 Foxbody I thought I might be able to use the radiator out of my 1974 F-100. After I measured I discovered that there was no way in hell that it was going in there. It would have either stuck up above the hood line by about 8 inches or it would be dragging the ground. Or at least close to it. I imagine that a 70's F-350 radiator is about the same size or bigger than a F-100 radiator. It is a good thought (I had the same one) but probably just isn't going to happen.
post #11 of 25 (permalink) Old 09-05-2012, 02:47 PM Thread Starter
I just put mine in and right now its about an inch from stock hood clearance in stock height, it is quite a thick radiator though.
overownt is offline
post #12 of 25 (permalink) Old 09-05-2012, 05:25 PM
BigRigTech's Avatar
A 92 F350 460 rad or aftermarket aluminum unit of the same size will work, I tried the Allstar unit I have here for my 92 F350 4x4 C&C dually.
472", A429's, 600HP
post #13 of 25 (permalink) Old 09-05-2012, 06:11 PM
Quoted: 139 Post(s)
Well that is a good deal. That has to be completely different than the F-100 & F-150 radiators of that era. Mine wasn't that thick (a 3 core), but it sure was tall.
post #14 of 25 (permalink) Old 09-06-2012, 07:07 AM Thread Starter
this is how it sits without modifying the engine bay, once my 460 is in I can go from there for clearance checks but I think it is a definate possibility
overownt is offline
post #15 of 25 (permalink) Old 09-11-2012, 09:50 AM Thread Starter
I have pictures in my build blog that I just added of the radiator with my motor in just resting pulley clearance, haven't modified it yet either.
overownt is offline
