New 545 build - Page 2 - 460 Ford Forum
post #16 of 44 (permalink) Old 06-13-2013, 05:15 PM Thread Starter
Originally Posted by butterbean View Post
did you find a intake? I have a performer RPM that I will sell you
yes I got a weiand stealth 8021
427 sideoiler is offline
post #17 of 44 (permalink) Old 06-13-2013, 05:23 PM Thread Starter
Originally Posted by bob460 View Post
Good idea would be to back cut the intake valves!!..........and get a custom camshaft for those heads.
Looking good
are custom grinds more expensive than picking one out of the catalog? the vale terrain is all I have left to get. I was thinking of going with Comp pro magnum rockers with 1.7 to 1 ratio.
when you say cut back the intake valves are you talking about the overall diameter?
post #18 of 44 (permalink) Old 06-13-2013, 05:32 PM Thread Starter
Here are some pictures of what I have done so far.
post #19 of 44 (permalink) Old 06-13-2013, 11:21 PM
bigblok86ranger's Avatar
Why not run the Ford Racing roller cam? If the results I have had with their 460 crate motor cam they put their research into the roller can and its gonna work pretty damned good and to top it off the heads are already set up for that cam.
Eric Millard
bigblok86gt@yahoo.com
528ci of N/A power
Circle R Racing Engines
Trick Chassis
Beloit,WI 53511
608-313-9197
http://www.trickchassis.com/
bigblok86ranger is offline
post #20 of 44 (permalink) Old 06-14-2013, 11:29 AM
Quoted: 65 Post(s)
Yes they are more expensive but not by much (maybe $30-40 more) but you will be better off, because you can choose where you want the power ( rpm range).
Back cutting the intake valves is only around $40 from what i have seen, best thing to do is get on to Lem, Randy Malik, Mad porter, carsbycarl, boss 429 to name few, they will steer you in the right direction.
By only back cutting the intake valves and getting a custom camshaft you will be min. 50+hp better off than by going with just a catalog cam.
bob460 is offline
post #21 of 44 (permalink) Old 06-14-2013, 12:36 PM
Quoted: 30 Post(s)
The 1.7 to 1 ratio rocker arms arre Chevy rocker arms and use different geometry than the 1.73 to 1 ratio FORD rocker arms.
DanE is offline
post #22 of 44 (permalink) Old 06-14-2013, 12:38 PM
Money-pit's Avatar
Quoted: 17 Post(s)
If you are running a Ford rear sump pan then you have the main bolt/stud in the wrong place. It goes in the # 4 cap left side.
Money-pit is offline
post #23 of 44 (permalink) Old 06-14-2013, 04:52 PM Thread Starter
It is getting a front sump pan.
post #24 of 44 (permalink) Old 06-14-2013, 05:04 PM Thread Starter
I don't want to rev it over 6500 so I would like to have power from say 2500 to 6000. the heads are M-6049-SCJB Super Cobra Jet heads I would like to have a cam that would work with the springs that came with it. "Assembled with solid roller springs: Closed seat pressure 240# @ 1.900"; Open seat pressure 625# @ 1.200"; Max lift .650"
If one of the venders would like to quote me a cam just let me know and I will PM you with the information you need.
also looking for a E85 carb.
post #25 of 44 (permalink) Old 08-18-2013, 10:06 AM Thread Starter
almost there. I will be running e85 13.5 to 1 compression, comp cam 34-710-9 .663 lift I/E and 226 duration @.05 lift I/E. looking at a 1050 carb will that be big enough? What spark plugs should I run with e85.
post #26 of 44 (permalink) Old 03-27-2014, 07:27 PM Thread Starter
12 second run
well I finally got to the track it ran 11.931 in the quarter mile at 112 mph still need to get more traction on launch. I have to peddle it for the first 60 foot.
post #27 of 44 (permalink) Old 03-27-2014, 07:34 PM Thread Starter
post #28 of 44 (permalink) Old 03-27-2014, 08:54 PM
What is the weight on the truck...gears...shift rpm... exhaust??
Damn girl... You look better than a new set of mud tires
1993 f350 38's 5 speed. Toy
521 p51 headed pump gas street motor
639 hp at 5600 rpm
670 ft/lbs at 4300 rpm
Imtruckinup is offline
post #29 of 44 (permalink) Old 03-27-2014, 09:05 PM
why don't you give all of us a update on how everything turned out and how the build was completed? what carb did you use? did you go with E-85? what stall did you use? I know I wanna know?????? you run at G-ville?
butterbean is offline
post #30 of 44 (permalink) Old 03-27-2014, 09:08 PM
^^^^^^^^ agree. Im curious
639 hp at 5600 rpm
