Hi everyone was just posting this to see if anyone could give me a recomendation on carb choice for my new big block which is currently being built,
specs are:
D1VE block stock crank and stroke 466ci
forged scat rods and forged pistons 030 over bore=4.390 compression 11-1
AFR 270 bullit cylinder heads
victor jr manifold
Lunati Voodoo Solid Roller cam 40340733
Advertised Duration (Int/Exh): 279/285
Duration @ .050 (Int/Exh): 249/255
Gross Valve Lift (Int/Exh): .675/.675
LSA/ICL: 110/106
Valve Lash (Int/Exh): .018/.018
RPM Range: 2800-7000
any advice will be appreciated
specs are:
victor jr manifold
LSA/ICL: 110/106
