So tonight I just realized I have a windage tray on the shelf. I see ARP has a stud kit with the 4 longer studs for the tray. As my block is fresh from the machine shop and had an align bore, can I just swap in the studs instead or does the bore have to be done with the new studs?
If the original align bore was done with studs and all you are doing is replacing those studs with ones for attaching the windage tray you would be good to go.
Forest
I just ordered a couple of main cap bolts with the stud on top from Lem Evans. Should work fine.
