I have multiple clients using this company's product with good feedback. I will be using them on my 1976 Thunderbird to clean up the front of the engine and shed weight.
You're not going to find a cheaper set up than what Scott posted, unless someone gives you a kit for free. I was going to suggest the same set up that I run from March, but if $264 for billet pulleys, brackets, and all the necessary spacers, adjusters, and bolts is too expensive, you're going to have to scrounge and get lucky. Stock stuff costs more if you can find it all, usually, and isn't nearly as pretty.
You're not going to find q cheaper set up than what Scott posted, unless someone gives you a kit for free. I was going to suggest the same set up that I run from March, but if $284 for billet pulleys, brackets, and all the necessary spacers, adjusters, and bolts is too expensive, you're going to have to scrounge and get lucky. Stock stuff costs more if you can find it all, usually, and isn't nearly as pretty.
I was shocked as I scanned ebay last evening. The prices being asked for oem brackets and pulleys was out of the park imo.
That being said I wasn't charging enough lol. :grin:
If you want a serpentine setup, you could grab pulleys from the late 80s-90s 460 truck engines. I'm not sure if the alignment would be correct though without using the truck engine's big ugly aluminum accessory brackets.
I messed around for a while adapting some original brackets to work with the help of another forum member. I'm sure I have 3-400 in mine after trying a few times and it's still not as nice as what you'd get in a kit. The headaches involved with rigging something to work right and then to make it cosmetically decent make it well worth spending the money.
If you have the room in your engine bay, the 1990 F-series with 7.5L has a dual belt serpentine system. You might be able to get the brackets at a salvage yard.
