What cam is this? I need specs - 460 Ford Forum
post #1 of 5 (permalink) Old 03-20-2017, 05:11 AM Thread Starter
ghostriderblk's Avatar
I measured .600 lift both int and exh with a 1.7 rocker but I would like to know the rest of the specs.
The cam says a514 then below it says np7074 with a circled M to the side
ghostriderblk is offline
post #2 of 5 (permalink) Old 03-20-2017, 05:13 AM Thread Starter
I'd like to say it's a a 514 cam but the lift doesnt match. I measured with and length of lobe subtracted and then multiply that by rocker ratio which I'm running a 1.7 ratio
post #3 of 5 (permalink) Old 03-20-2017, 10:25 PM
Quoted: 51 Post(s)
A514 CAMS are meant for a 1.73 ratio rocker, they were made by crane
BOSS 429 is offline
post #4 of 5 (permalink) Old 03-21-2017, 06:16 AM Thread Starter
Do you have a link to any specs? I went on cranes Web and I don't see any thing.
post #5 of 5 (permalink) Old 03-21-2017, 01:12 PM
Quoted: 180 Post(s)
The M-6250-A514 cam and tappet kit features an induction hardened steel mechanical roller cam with the following specs:
Feature Intake Exhaust
Max lift .647" .647"
Duration @ .050" lift 254 258
Centerline 107 117
Lobe separation 112
Events @ .050" open 20 BTC 66 BBC
close 54 ABC 12 ATC
Lash -hot .020" .020"
-cold* .014" .014"
Ford Racing CJ aluminum heads, other heads may require a different cold lash spec.
While the cam is mild with regard to spring requirements it does not offer enough exhaust timing.
Some years ago I bought a bunch of the kits. Reground the cams with better lobe profiles and notched the crane non pressure oiled roller lifters. So far very good results.
Imo a 4 degree split is simply not enough for most all of the cylinder head choices we have available to date.
http://R-H-P.biz
