Comp cam XE262H in 460 - 460 Ford Forum
post #1 of 26 (permalink) Old 04-17-2017, 11:08 AM Thread Starter
Quoted: 10 Post(s)
So I picked up a fresh rebuilt 460 it was sitting for a couple years and this weekend I fired it up. Started up no problem sat and idled with out even having to pump it or feather the throttle. I was told it has a RV cam in it and by the exhaust tone sounds pretty mild. Everything was redone on this engine even the heads I haven't pulled the manifolds off to see if the hump was ground out yet. It has D3 heads on it. I have to pull the engine and while I have it out I was thinking about swapping the cam out to the comp XE262H before I put in my 66F100. My question will there be any issues installing this cam in a almost stock rebuild? I had a big build planned then money became a problem so I'm going this route until I get more money. I'm going to be running a C6 tranny headers RPM intake
66F100466 is offline
post #2 of 26 (permalink) Old 04-17-2017, 12:06 PM
Quoted: 192 Post(s)
If the engine is an oem style rebuild the static c/r will be less than 8 to 1. Until such a time as you can raise the static c/r leave the cam as is.
Best bang for time and $$ spent is:
Straight up cam timing
Properly curved distributor
Save the RPM intake for later.
http://R-H-P.biz
post #3 of 26 (permalink) Old 04-17-2017, 08:02 PM Thread Starter
Quoted: 10 Post(s)
Is there anyway of checking the compression ratio with the engine still together? I'm going to go through all the gaskets except the head gaskets maybe I can see if they put better pistons in it from the bottom when I take the pan off...by part # or something?
post #4 of 26 (permalink) Old 04-17-2017, 09:00 PM
Quoted: 192 Post(s)
You can check cranking PSI as well as looking into the spark plug hole with a bore scope to ID pistons.
http://R-H-P.biz
post #5 of 26 (permalink) Old 04-17-2017, 09:43 PM Thread Starter
Quoted: 10 Post(s)
Thanks for the info I will definitely do that.
post #6 of 26 (permalink) Old 04-21-2017, 09:44 AM Thread Starter
Quoted: 10 Post(s)
I got a cheap borescope off amazon and looked inside the pistons are flat with a oval out them on one side like a reverse dome piston. I'll try and post a picture
post #7 of 26 (permalink) Old 04-21-2017, 09:53 AM Thread Starter
Quoted: 10 Post(s)
They look just like this.
post #8 of 26 (permalink) Old 04-21-2017, 09:54 AM Thread Starter
Quoted: 10 Post(s)
Not really an oval I guess
post #9 of 26 (permalink) Old 04-21-2017, 11:36 AM
Quoted: 192 Post(s)
Typical sealed power H418cp builder piston.
Silvolite and caldwell look the same.
http://R-H-P.biz
post #10 of 26 (permalink) Old 04-21-2017, 08:21 PM Thread Starter
Quoted: 10 Post(s)
So probably the 8.5 like you were saying unless they had the heads shaved the cylinder walls looked great looks like it doesn't have any miles on it.
post #11 of 26 (permalink) Old 04-21-2017, 08:48 PM
Quoted: 192 Post(s)
Unless the block has been decked and the heads decked the static c/r will be LESS than 8 to 1...
http://R-H-P.biz
post #12 of 26 (permalink) Old 04-22-2017, 06:44 AM
4604X4's Avatar
Quoted: 26 Post(s)
A set of early C9, D0 heads with the smaller 75cc chambers would boost compression - or better yet some aftermarket aluminum heads (which would already have the screw-in-studs, valve springs, larger valves and better flow, hardened ex seats, better seals, etc.).
The bump in compression (to around 10.5?) would certainly improve performance - although 10.5 might be a little high for street use/pump gas.
4604X4 is online now
post #13 of 26 (permalink) Old 04-22-2017, 08:26 AM
Quoted: 6 Post(s)
I might want to do this. What borescope did you buy and could you clearly see the top of the bore where the ridge develops? Would you buy a different scope now?
OldGuyOldTruck is offline
post #14 of 26 (permalink) Old 04-22-2017, 12:25 PM
Quoted: 192 Post(s)
In a later model oem style rebuild with 22 / 23 cc dished hyper pistons with 1.752 CH, no or minimal decking leaving pistons .035"+ down the bore and 75 cc chamber early heads or 74 cc chamber aluminum offerings will bring static c/r to about 9 to 1 with a .075"+ quench distance.
22 cc dished piston
72 cc chamber
pistons at ZERO deck height puts static c/r at 9.92 with the UEM calculator.
http://R-H-P.biz
post #15 of 26 (permalink) Old 04-22-2017, 02:13 PM
4604X4's Avatar
Quoted: 26 Post(s)
Do those pistons OP has havea 22 or 23cc dish? The specs on the OP's pistons on say the dish is .240 deep. But they don't give a "cc" for the dish.
I have the TRW 2404F which have a .180 depression and that is a 22cc dish. But the TRWs have a round dish and the OPs have an oval dish.
