Very tight budget build - 460 Ford Forum
 2Likes
  • 1 Post By DanE
  • 1 Post By The Mad Porter
post #1 of 15 (permalink) Old 04-19-2017, 06:16 PM Thread Starter
Hey guys,
I am building a 460 to throw into a new crown vic for the heck of it. I am looking to keep this on a super tight budget but would like to get near 350hp at the crank. Here is my plan:
Picked up a 460 out of a '71 Mark III with c9ve heads. Stock rebuild on the bottom end, maybe better bolts. Id like to go with an performer rpm intake and 750cfm carb.
What I don't know enough about is the heads, I will be porting them but I'm not sure what to do with the rockers/springs. I really would like to avoid spending the $500 on a cam+matching springs and hardware from comp cams.
So my question is, what cam would work with stock c9ve springs and would I even get close to 350 or am I dreaming? Do I need to shave a bit off the head to up compression? Pistons will be stock.
I searched the forums but to no avail.
Bigblockpanther is offline
post #2 of 15 (permalink) Old 04-19-2017, 09:27 PM
Quoted: 150 Post(s)
You can get 350 flywheel horse power easily.
Take a look at this thread. It has the blueprints you need.
460 Horsepower Chart (revised 1/24/09)
MrScharfenberger is offline
post #3 of 15 (permalink) Old 04-19-2017, 09:41 PM Thread Starter
Yeah, I was looking at that. When they say stock rockers is it implying stock springs as well? Or is it implying that springs matching the cam thats suggested should be used as well?
post #4 of 15 (permalink) Old 04-19-2017, 09:45 PM
Quoted: 32 Post(s)
Originally Posted by Bigblockpanther View Post
Hey guys,
Seeing as how an original engine from a 71 Mark III was rated at 365 HP and had 10.5 to 1 compression, and you are on a tight budget, spend your money on machine work.
As to porting the heads, do your porting within 1 1/2" of the valves along with a proper valve job.
Deck the block (aim for a .040" quench) and set all clearances in the engine for its intended usage. Use all factory bolts. Install headers and a free flow exhaust. Put a proper curve in the distributor and tune the carb. Having done this, that engine will surprise you.
When the dust has settled from the conversion and you budget has improved, replace the carb, intake, and a custom cam.
Again, that stock engine, set up properly, will run strong.
BOSS 429 likes this.
DanE is offline
post #5 of 15 (permalink) Old 04-19-2017, 10:41 PM Thread Starter
Hey guys,
By setting the clearances you mean bearing clearances in the bottom end, correct?
Would a machine shop need the head gasket and head to deck the block to 40 thou quench height?
post #6 of 15 (permalink) Old 04-20-2017, 10:48 AM Thread Starter
And wouldn't decking the block raise compression even more? Id like to stick with 91 octane as thats the highest i have available.
post #7 of 15 (permalink) Old 04-20-2017, 12:56 PM
4604X4's Avatar
Quoted: 42 Post(s)
What Is The Ideal Quench Height? - Hot Rod Network
4604X4 is offline
post #8 of 15 (permalink) Old 04-20-2017, 02:37 PM Thread Starter
yeah I read about quench heights but isn't decking the block going to raise compression on an already high compression engine?
post #9 of 15 (permalink) Old 04-20-2017, 04:00 PM
Quoted: 32 Post(s)
You can lead a horse to water............................................. .....
DanE is offline
post #10 of 15 (permalink) Old 04-20-2017, 04:14 PM
Quoted: 8 Post(s)
You want the machinist to mill the deck to achieve "zero" deck meaning the piston is as close to "flush" as possible with the top of the block. Use a .039-.041 compressed head gasket and your quench height is set optimally for a street build. The slight increase in static compression ratio is more than offset by establishing the proper quench height as far as detonation resistance is concerned.
1973 Mustang Convertible
TommyK is offline
post #11 of 15 (permalink) Old 04-20-2017, 06:56 PM Thread Starter
Got it, thanks!
post #12 of 15 (permalink) Old 04-20-2017, 08:38 PM
Quoted: 215 Post(s)
Remember that the original early 460 pistons had a smallish 11 cc dish and a 1.760" compression height sitting at .010" below deck offering approximately 10.5 to 1 static c/r. In 1971 ford raised the deck from 10.300" to 10.310" leaving the pistons another .010" down for .020" below deck.
If you use builder style replacement pistons like the H418CP with the 22 to 23 cc dish you will have to deck the never decked block to 10.282 to achieve 0 deck height. With a 75 cc chamber your static c/r will be 9.66 to 1. With a 72 cc chamber 9 9 to 1 static.
If you intend on keeping the stock cam I would not deck the heads at all to keep static c/r compatible with the short cam timing. We offer a custom ground hydraulic cam and lifter kit with Drop in single springs, retainers and locks for $369.95 plus shipping so there is no reason to keep the oem cam and oem springs which were inadequate for even the stock cam imo.
As strong as those early engines were on good 96 octane premium fuel the actual output with manifolds, dual exhaust, 600 cfm 4300 carb and as delivered ignition curve was more on the order of 325 hp. The advertised numbers were sae gross hp with optimized exhaust and ignition timing.
Headers and a properly curved distributor might get you close especially if you clean up the cylinder head ports...
The performer intake is more appropriate for your intended use and hood clearance.
We build a 460 crate engine with those H418 cp builder pistons, NOS F6TE truck rods, budget ported D0VEs, PRW roller rockers, performer intake, 213/227 custom voodoo cam, 750 carb, properly curved distributor with 9.6 to 1 static c/r that makes 440 hp with the jomar power cone spacer. Use it as a template to do your build.
This same combo with out ported heads drops to about 360 hp give or take with headers.
ParaPsy likes this.
http://R-H-P.biz
post #13 of 15 (permalink) Old 04-20-2017, 10:20 PM Thread Starter
Lots of great info, really appreciate it!
Would it work well to get your cam/spring kit, port the heads, new intake and headers and leave the block and rods stock?
post #14 of 15 (permalink) Old 04-20-2017, 10:39 PM
Quoted: 215 Post(s)
If the bottom end is still oem the static c/r will be too high for the combo I mentioned and the next two steps up being 460 hp and 500 hp with rpm intake.
You need to moderate static c/r, tighten quench and have the proper cam ground to run on pump premium.
http://R-H-P.biz
post #15 of 15 (permalink) Old 04-20-2017, 11:00 PM Thread Starter
So it sounds like the best budget option would be to port heads, headers, and properly set the timing/advance. And cam/decking/pistons/intake would be the next step up.
Would the performer intake help at all without an upgraded cam?
