Decent street strip 460 - 460 Ford Forum
post #1 of 9 (permalink) Old 04-20-2017, 08:49 PM Thread Starter
Hi guys
Wanted to get your thoughts on the combination I'm planning.Its a .03 over 460 kb138 pistons, Sir rods, ex284h cam tfs290 heads stealth intake. With.040 head gasket .005 below deck should be around 9.8 compression. Its going in a 1970 fairlane with 3.89 gears and a 2500 converter. It will be street strip driven with 93 octane. I am also considering worked heads from RHP, but I haven't heard back from Scotty yet. Anyone see cost effective room for improvement?
thomcat is offline
post #2 of 9 (permalink) Old 04-20-2017, 09:32 PM
Quoted: 31 Post(s)
Use forged pistons.
DanE is offline
post #3 of 9 (permalink) Old 04-20-2017, 10:08 PM
Quoted: 192 Post(s)
Originally Posted by thomcat View Post
Hi guys
Tom,
Sorry for the oversite on returning your call. I'm buried.
I will call tomorrow.
http://R-H-P.biz
post #4 of 9 (permalink) Old 04-21-2017, 11:41 AM Thread Starter
Wouldnt I be farther ahead in running the tighter tolerences of the KB pistons as opposed to forged? Gives me a tighter quench.
thomcat is offline
post #5 of 9 (permalink) Old 04-21-2017, 11:50 AM
Quoted: 192 Post(s)
You are confusing piston to wall clearance with quench clearance.
http://R-H-P.biz
post #6 of 9 (permalink) Old 04-21-2017, 01:28 PM Thread Starter
What I meant was that closer cylinder to bore clearance reduces piston rock and therefor allows you to safely run tighter piston to head clearance. If I'm wrong let me know
thomcat is offline
post #7 of 9 (permalink) Old 04-21-2017, 01:28 PM Thread Starter
Piston to bore, mybad
thomcat is offline
post #8 of 9 (permalink) Old 04-21-2017, 04:15 PM
Why spend all the money on a build and have it's longevity hinging on hyper pistons?
slowride is offline
post #9 of 9 (permalink) Old 04-21-2017, 05:12 PM
Quoted: 192 Post(s)
We have used hyper pistons in our crate engines for years at the 500 hp / 5,200 rpm peak and under combinations with 0 trouble. Setting the top ring gap is essential on ANY hyper piston even the sealed power units.
Is a forged piston better in a mild application? Only if you plan on spraying it with nox or detonating it to death.
Each has its place.
http://R-H-P.biz
