Scat 9000 4.5" @ 770hp - 460 Ford Forum
 3Likes
  • 2 Post By 4604X4
  • 1 Post By MrScharfenberger
post #1 of 6 (permalink) Old 05-16-2017, 11:17 PM Thread Starter
Assuming the machine work, assembly, tune and are correctly done, will a Scat cast 9000 4.5" crank in a 557, peaking at 6100, live long? The engine is arleady built and dyno'd - just trying to get a feel for longevity and decide if it's worth having the cast crank swapped for a forged unit.
Intended use is mud, sand, and plenty stop sign to stop sign.
Build specs:
  • CR = 11.7:1
  • Vehicle weight = 5400lbs
  • gear ratio 5.39:1
  • tire size = 42.5"
  • C6 with a flash stall of 3400
ford385 is offline
post #2 of 6 (permalink) Old 05-17-2017, 06:43 AM
4604X4's Avatar
Quoted: 34 Post(s)
I'd be more worried about the transmission.
The Mad Porter and bob460 like this.
4604X4 is offline
post #3 of 6 (permalink) Old 05-17-2017, 07:35 AM
Quoted: 77 Post(s)
Is this the engine Carl built?
At that rpm it will be fine.........have faith in your builder!!
Cheers, Bob
bob460 is offline
post #4 of 6 (permalink) Old 05-17-2017, 09:45 AM Thread Starter
Understood - The first trans busted the input shaft off in the tq convertor.
The current unit is a Broader Performance wide ratio unit (rated at 1000hp) with his billet convertor in front of it.
ford385 is offline
post #5 of 6 (permalink) Old 05-17-2017, 09:49 AM Thread Starter
Cheers, Bob
Hey Bob, it's not the same engine that Carl built for me.
Thanks for the feedback.
ford385 is offline
post #6 of 6 (permalink) Old 05-17-2017, 09:50 AM
Quoted: 139 Post(s)
I ran the crap out of a SCAT 9000 4.3 stroke crank with a motor making somewhere around 800 HP for years and never had an issue. I took it to 8000 RPM quite often. I ended up parting the motor out during my next build and sold the rotating assembly when done with it. It was fine and is running in a different motor now. I wouldn't worry about it.
ford385 likes this.
MrScharfenberger is offline
