I'm putting my 460 back together checking all the clearances and such. I find the front cam oil passage to appear mostly blocked by the main bearing. It's this way in another block I have also. Question is so any of you all modify it to center up on the bearing oil opening? Also turning 7500 rpm my mains came out to 2.5 thousands and the rear Main to 2.2. The rods I just started checking. Got 1.7 on the first one. Taken using a micrometer and dial bore gauge with 0.0001 readout standard brand tool. Using 20w50 vr1
