Valve Lash Adjustment Charts - Page 2 - 460 Ford Forum
Engine Tech Archive A collection of all posts from the old Network54 forum
post #16 of 25 (permalink) Old 06-17-2012, 06:34 AM
nice info. not to be a a$$ but you have a chart for X brands. i run a ford but like all three brands and run them to.
Drag week quickest street rod
2009 2010
quick 52 is offline
post #17 of 25 (permalink) Old 06-21-2012, 06:55 PM
Does the three position chart system work as well as the 90* chart. I used the three position system, it seems to run ok but I just want to make sure it runs the best it can. The system I used was a lot easier because I adjusted them by myself.
Thanks.
'64 Galaxie 500 XL 499/C6, '06 Mustang GT
GT300TD is offline
post #18 of 25 (permalink) Old 06-21-2012, 08:31 PM
D Pope's Avatar
You can always get a cylinder so the valves are in the split overlap position (both valves open) and set the valves on the cylinder that's four down in the firing order.
1949 Mercury coupe
Nosed, Decked, Frenched
58 T-Bird interior
472 w/toploader 4 speed OD
Performer RPM w/Holley 3 barrel
Isky 304 degree solid cam
Narrowed 3.25 9.5 inch with Detroit Locker
D Pope is offline
post #19 of 25 (permalink) Old 09-22-2013, 12:15 PM
68formalGT's Avatar
Quoted: 33 Post(s)
Originally Posted by Danny Cabral View Post
Excerpt from Bret Powell's post on setting valve lash with big camshafts:
Adjust the intake when the exhaust starts to open.
Adjust the exhaust when the intake is almost closed...not when it starts to close.
What happened to the 3 position chart?
Joey
68formalGT is offline
post #20 of 25 (permalink) Old 09-22-2013, 01:58 PM
ag460torino's Avatar
3 position chart....
give me a sec and I will post a 3 position chart
ag460torino is offline
post #21 of 25 (permalink) Old 09-22-2013, 05:00 PM
68formalGT's Avatar
Quoted: 33 Post(s)
Thank you. It looks like you found that in a book if so what book did you find it in if you don't mind me asking?
Joey
post #22 of 25 (permalink) Old 09-22-2013, 11:19 PM
books
that is out of "how to rebuild ford v8 engines" by Tom Monroe. The other book with good engine code info is " how to build max performance ford v8's on a budget" by George Reid
Call on me anytime if I can help......
Auggie
post #23 of 25 (permalink) Old 09-23-2013, 02:41 PM
68formalGT's Avatar
Quoted: 33 Post(s)
Thanks again Auggie.
Joey
post #24 of 25 (permalink) Old 10-07-2013, 05:56 PM
Smile 3 position method
Crankshaft at TDC on compression stroke
#1 #7 #8 Intake
#1 #4 #5 Exhaust
Rotate crankshaft clockwise 180* (half turn)
#4 #5 Intake
#2 #6 Exhaust
Rotate crankshaft clockwise 270* (3/4 turn)
#2 #3 #6 Intake
#3 #7 #8 Exhaust
GT300TD is offline
post #25 of 25 (permalink) Old 10-08-2013, 04:20 PM
I use this procedure on everything - solid or hydro. EOIC works, you don't need a chart or a firing order, just go one cylinder at a time. This is specifically directed at the questions I used to get about setting hydros but I use the same on solids and get it done.
http://raceabilene.com/kelly/hotrod/valveadj.html
Pick a cylinder.
Bump the motor until the Exhaust valve starts up. Intake is now on base circle.
Loosen the intake lock nut.
WAIT a minute or so, to let the plunger relax.
Twirl intake pushrod between thumb and forefinger (hold gently) and tighten the lock nut until you feel the pushrod stop turning. A little practice is all it takes. You will know - it stops right away, unless you are turning it with pliers. This is zero lash.
Tighten locknut 1/2~3/4 turn.
Bump the motor until the Intake is almost down. Exhaust is now on base circle.
Loosen the exhaust lock nut.
Twirl exhaust pushrod between thumb and forefinger (hold gently) , etc...
Repeat as necessary.
1967 Falcon 4 door
Owner built, owner abused.
http://raceabilene.com/misc/hisnherspic.jpg
Falcon67 is offline
