521 Twin turbo build - 460 Ford Forum
post #1 of 39 (permalink) Old 02-20-2011, 05:30 AM Thread Starter
This is my new project, twin turbo with A-460 heads, forged 4,3 "rpm" crank, billet I-beam rods, Icon forged pistons 22cc reversedome, stock block with arp studs, custom stainless steel 2,25" twin-entry style headers, EFI and e-85 fuel, flat tapet mek cam 245/255 and 112lsa. The turbos are god for 1500+ hp but I dont think this block can handle that so I go for 1200hp and around 1 bar boost....
Sweden Mustang 545 is offline
post #2 of 39 (permalink) Old 02-20-2011, 08:08 AM
I love the look of the intake!
What size turbo's/throttle body are those and what efi are you gonna use?
Looks like a cool build!
Any would like to see more pics and info on the rest of the car.
Mike
dirt_worker is online now
post #3 of 39 (permalink) Old 02-20-2011, 01:56 PM Thread Starter
Mike
It is GT45 turbos, the throttle is 90mm, I use a Swedish EFI Nira, nice stuff!!, the car is a street legal Mustang 67....
post #4 of 39 (permalink) Old 02-20-2011, 05:27 PM
That thing looks SUPER!!
I've been thinkin Turbo's and EFI for the last few years on my stroker....finally steppin up to A heads right now. Im totally envious!
Mike
post #5 of 39 (permalink) Old 02-21-2011, 05:32 AM
crittersf1's Avatar
You'd be surprised at what that stock block can handle if you stay on top of the tune.
crittersf1 is offline
post #6 of 39 (permalink) Old 02-28-2011, 11:29 PM
Wow that has some serious potential.
Nice
G-code
http://i201.photobucket.com/albums/a...elake3-1-1.jpg
Going fast is only half the fun....what you make go fast is the other.
G-Code is offline
post #7 of 39 (permalink) Old 03-02-2011, 10:58 AM
What did you do with that aluminum 699 cin? You are using the heads and the extra intake from the 699 engine.
kjebba is offline
post #8 of 39 (permalink) Old 03-03-2011, 02:21 AM Thread Starter
The 699 (now 703) are still complete and for sale, is other heads on this engine but the manifold are the extra I have for the 699 engine. The reason to engine swap are that I hope this turbo setup are more street friendly and still have same horsepower or more than the 699...
post #9 of 39 (permalink) Old 03-03-2011, 06:00 PM
wow..
RyNo is offline
post #10 of 39 (permalink) Old 03-04-2011, 04:48 AM
Finmach's Avatar
Very nice Mustang you got there. Friend of mine is building a little bit of similar '67 GT-500 replica only with naturally aspirated Boss 429 with Heidts front end and tubbed rear.
Keep up the good work with the car. That is good looking car. Updating to A460 block would be such a bad idea in a long run.
I wouldn't mind seeing your Mustang when it's ready. We have here in Finland Ford Nationals at the 9th of July in Alastaro racing circuit. It is 67 km (42 miles) from ferry harbour (Stockholm Sweden - Turku Finland). If something brokes, short tow/trailerin to Harbour. Unfortunately Ford Nationals are at the same time as the Swedish mega party/cruising Powermeet as it has been now for the last three years.
All the true Finnish Ford loyalist have been skipping the Powermeet for three years in a row and attending to Ford Nationals. 2010 we had:
65 US FoMoCo cars on dragstrip
33 US FoMoCo cars on open track
32 US Fomoco cars on autoslalom
+several cars at the car show etc.
- '72 Mach 1 460 (A429+G429)+TKO600+M9" DL
- intermediate go fast project
TOTAL PERFORMANCE
Finmach is offline
post #11 of 39 (permalink) Old 03-04-2011, 09:46 AM
wj
wj's Avatar
Nice build!
Tell more that efi?
You can take near 2000hp with GT45:s what is turbine AR and engine top rpm?
Why e85? Rules?
Block can hande easy 1800hp with concrete and fourbolt main caps. I have one set for sale if you are interested
There is modified main studs 1/2" > 14mm 12.9 grade bolts. Cheap and easy mod
wj is offline
post #12 of 39 (permalink) Old 03-05-2011, 02:40 AM Thread Starter
Some more work done...
post #13 of 39 (permalink) Old 03-05-2011, 02:56 AM Thread Starter
I have start to put the engine together.
The new forged rpm crank in the block.
I have notch the block so it fit the a-460 heads better.
The parts ready to take place in the block, Icon/kb forged pistons and rpm I-beam "billet" rods.
post #14 of 39 (permalink) Old 03-05-2011, 03:39 AM Thread Starter
Originally Posted by wj View Post
Nice build!
Tell more that efi?
Why e85? Rules?
Here is the spec on the turbos, is china stuff.
Kompressor 066 A/R
Turbin 1,05 A/R
Inlet 109mm
Outlet 109mm, V-band klämma
Inducer 70mm
Turbinhjul 80mm
Trim 49
360 Lager
I use e85 for the higher oktan and it is cheap and easy to find on gas station here in sweden.
I have 4bolt caps, but it is lot off work to fit this in the block, so I do this on another block and change later or maybe go for the a-460 block in the next step....
post #15 of 39 (permalink) Old 03-06-2011, 11:01 AM
wj
wj's Avatar
How about dyno?
Nice see how 1.05AR work with 521"
I have experience 79mm 1.05AR turbine with 429, 460 and 598"
With 429 and 460 work just fine but with 598" come problems ext temp and press.
Next season i try 89mm 1.22AR turbine.
Write some info how engine work
There is not too much bbf turbo info..
wj is offline
