A-headed 521" pump gas build. - Page 2 - 460 Ford Forum
post #16 of 33 (permalink) Old 04-12-2013, 10:08 AM Thread Starter
got a couple part back: old style TFS "low rise" Ceramic coated by Embee Performance
Old style T/R re-polished:
I need to get a set of valve covers and we should be ready for the dyno.
Jon
http://i201.photobucket.com/albums/a...elake3-1-1.jpg
Going fast is only half the fun....what you make go fast is the other.
G-Code is offline
post #17 of 33 (permalink) Old 04-12-2013, 06:24 PM
Quoted: 39 Post(s)
Smile
You boat guys are show offs!
Nice job Chief Cloud!
B F Evans Race Parts
270-278-2376
Lem Evans is offline
post #18 of 33 (permalink) Old 04-12-2013, 11:25 PM Thread Starter
can't wait to see what the TR I got from you is going to do at 6,800- 7,200 range
G-Code is offline
post #19 of 33 (permalink) Old 05-03-2013, 06:56 PM
Any updates yet?
dirt_worker is offline
post #20 of 33 (permalink) Old 05-12-2013, 12:12 AM Thread Starter
had to cancel the dyno date, had a couple of conflicts get in the way. Will get a new date set this coming week.
G-Code is offline
post #21 of 33 (permalink) Old 06-14-2013, 12:59 AM Thread Starter
well got most of what I wanted done accomplished today. Exceeded my goal of 825hp with the single carb. Had a stupid problem with the TR system so didn't get to run it today. Probably go back sometime in July and play for the day.
After we figured out the tunnel ram wasn't going to work we decided to put the single back on and do some more pulls. Dropped the 20/50 VR-1 oil and put in some Mobil 1 10/30 and then swapped out the 1,200 Domi and put on a 950HP to see what would happen. I'll post some pics of the charts now, if I have time tomorrow I'll scan a few and post them.
We ended up at 11.25:1 compression, started with 28* timing, went to 30 then 32* and kept it at 32* with the 91 octane. Made 13 pulls in all.
Here are some of the results:
comparison pulls of 1,200 vs 950 ultra HP carb:
950HP made peak trq of 685 lbs ft at 5,100 vs Dominator of 700 lbs ft peak at 5,100
the 950 made 803 at 6,700 for max hp vs 843 at 6,800 for the 1,200.
the 1,200 was pulling 1.8 " vac at 6,800 the 950 was pulling 2.5" at 6,800.
the Mobil 1 10/30 was worth 10 hp over the 20/50 VR-1 and 10 lbs ft at 5,100
I'll post some more info later. hopefully I can get my cell phone video posted.
Jon
G-Code is offline
post #22 of 33 (permalink) Old 06-14-2013, 05:10 AM
Excellent test G-Code!!....1.8 inches of vacuum with the 1200 Dommy??....wow!! theres more left in her!!
Other than using a TR, it would be sweet to see a back to back comparison of your 1200 Dommy, vs. a SV-1 carb (if you had one to use, that is!!).
Interesting about the difference in power numbers by switching oils.
TorinoStyle2 is offline
post #23 of 33 (permalink) Old 06-14-2013, 10:14 AM
Quoted: 77 Post(s)
Originally Posted by bob460 View Post
You'll hit 800hp by 6000rpm
Sweet build.
Whats the intended use?
Cheers, Bob
I was CLOSE........lol
Nice build Jon..................the 950 carb done real well aswell, make a killer street engine!
bob460 is offline
post #24 of 33 (permalink) Old 06-14-2013, 01:27 PM Thread Starter
yes you were pretty close.
It was built with the Danny Bee so we could move the cam around, thought about advancing it 2-4* to see what would happen but it was making the power right where I wanted it so we left it alone. It would be interesting to see what the trq would do if advanced 4*.
G-Code is offline
post #25 of 33 (permalink) Old 06-14-2013, 07:09 PM Thread Starter
best pass:
T/R:
Now that I'm going to go back to run the tunnel ram, I'm thinking of running an A/B test
Anyone with any experience running an engine this size with both styles of T/R ?
G-Code is offline
post #26 of 33 (permalink) Old 06-14-2013, 07:44 PM
Quoted: 39 Post(s)
Thumbs up
Get it done Jon.
270-278-2376
post #27 of 33 (permalink) Old 06-14-2013, 07:52 PM Thread Starter
Get it done Jon.
You might like this Lem:
click on to play video
G-Code is offline
post #28 of 33 (permalink) Old 06-14-2013, 08:39 PM
Quoted: 10 Post(s)
Fantastical!
Like that you ran it with a smaller carb.
windsor is offline
post #29 of 33 (permalink) Old 06-14-2013, 10:31 PM Thread Starter
at the cost of 6 lbs of oil psi in this case. the 20/50 was running 61-62 psi from 5,800-6,800
the 10-30 was 55psi from 4,800- 7,000. I was pulling oil psi off the back of the engine so it should have been getting 65 psi at the crank, or so I've been told. I think I'm going to mount a second gauge in the boat to take a reading at the port at the fuel pump boss and see what it is.
In the past I've swapped Mobil 1 20/50 for conventional 20/50 a few times and have seen as little at 8 hp and the max of 14 hp. 20/50 for 20/50 the extra power was when the oil temp was at or above 180*
G-Code is offline
post #30 of 33 (permalink) Old 06-15-2013, 10:01 AM Thread Starter
Hey Lem,
I ran it with my old "low rise" TFS single with it pulling 1.8" vac I wonder what my new style high rise single that's on the 565 would be worth on this engine?
I'm thinking it could break 860 with a single 4 on pump gas....... ?
G-Code is offline
