P51 heads - 460 Ford Forum
post #1 of 9 (permalink) Old 02-14-2013, 09:30 PM Thread Starter
P51 heads
I have a Edelbrock headed bbf. if I wanted to go to a set of p51's do I have to change pistons?
cam2 is offline
post #2 of 9 (permalink) Old 02-14-2013, 09:37 PM
CarsByCarl's Avatar
Quoted: 73 Post(s)
Either new pistons, or add new intake valve reliefs to the current pistons, which can be done without taking apart the short block.
CarsByCarl is offline
post #3 of 9 (permalink) Old 02-14-2013, 09:50 PM Thread Starter
If it were you would you bypass the p51's and go straight to a A head with new pistons of course.
cam2 is offline
post #4 of 9 (permalink) Old 02-14-2013, 10:36 PM
CarsByCarl's Avatar
Quoted: 73 Post(s)
Well, that would depend on what I was trying to achieve.
post #5 of 9 (permalink) Old 02-15-2013, 01:18 PM
GECSR's Avatar
changing valve reliefs w/o engine disassembly
So, how much material would one be removing from the top of the piston if this can be done "in block"? Are you talking about welding a cutting tool to the head of a valve and bolting the head to the block, then cutting the relief as such?
Greg C.
89 Fox 466 9.80's @137
71 Mach I 429CJ Driver
GECSR is offline
post #6 of 9 (permalink) Old 02-15-2013, 02:38 PM
CarsByCarl's Avatar
Quoted: 73 Post(s)
There's no reason to make your own, you can buy them from several sources. Fits in place of the valve and attaches to a drill. Pocket depth would depend on the cam being used.
post #7 of 9 (permalink) Old 02-18-2013, 01:20 PM
GECSR's Avatar
Thanks! Any vendors come to mind that carry this type of tool?
Greg C.
GECSR is offline
post #8 of 9 (permalink) Old 02-18-2013, 02:19 PM
CarsByCarl's Avatar
Quoted: 73 Post(s)
http://www.lindytools.com/
post #9 of 9 (permalink) Old 02-22-2013, 01:30 PM
GECSR's Avatar
Tool
Thanks so much!
Greg C.
GECSR is offline
