598 TFS A-460 Nitrous Build and Dyno Results - 460 Ford Forum
post #1 of 36 (permalink) Old 07-24-2013, 04:02 PM Thread Starter
I just thought I would share my results from my 598 A460 nitrous build. At 9am on the day of the dyno, it was in the upper 70's with 93% humidity and by mid morning it was in the mid to upper 80's with around 80+% humidity. We also ran this motor (which I didn't agree with) on VP NO2 as this is the fuel the motor would see when on the bottle. So needless to say the power numbers are down a little bit due to this, and more timing was used than would have been necessary with better air and different fuel.
How much power do you think this setup should make? I will post the dyno sheets once my scanner starts working again.
Engine Specs
IDT Ultra Block
Scat 4.5 crank
Scat 6.8 rods
Racetec Gas Port Pistons 4.600"
12:1 Compression
WW Shaft Rockers
Nitrous Cam
TFS A460 - New with some chamber and intake port work (gasket match)
TFS Cast Intake - only port matched to the heads
Ouick Fuel 1250
1" Open Spacer
Crank Trigger, MSD Dist
Moroso 4 Vane Vaccum pump
Oil: Brad Penn 20w50
Fuel: VP NO2
SuprSlow50 is offline
post #2 of 36 (permalink) Old 07-24-2013, 06:18 PM
557MAV's Avatar
Cam specs??
If cam is around 850-825..290@50..
30' timing
985 hp
1972 maverick 3200lbs street car. Steel and glass.
Jon kaase 598. 8.57@ 160
557MAV is offline
post #3 of 36 (permalink) Old 07-24-2013, 07:12 PM
bigblok86ranger's Avatar
With the relatively low compression and the smallish carb I would guesstimate ~925-950
Eric Millard
bigblok86gt@yahoo.com
528ci of N/A power
Circle R Racing Engines
Trick Chassis
Beloit,WI 53511
608-313-9197
http://www.trickchassis.com/
bigblok86ranger is offline
post #4 of 36 (permalink) Old 07-24-2013, 09:32 PM
Quoted: 46 Post(s)
even with nos thats not the fuel for that combo for max hp
815-712-8738
Dynoed or Test ran
CLYINDER HEAD PORTING
BOSS 429 is offline
post #5 of 36 (permalink) Old 07-24-2013, 10:30 PM
soupbean's Avatar
Q16
RMS Motorsports
97 Mustang
598 A Head
Current Best 1.27 60ft 5.57 1/8 mile @125 3100lbs
soupbean is offline
post #6 of 36 (permalink) Old 07-25-2013, 12:46 PM Thread Starter
Well, it is going to see a pretty healthy dose of nitrous. I am not sure if VP NO2 will be a better fuel than C16, which I have always used, but I figured I would try it. I wanted to dyno it on C12 or something similar, since the NO2 fuel was going to be overkill and not give me a realistic base number.
I honestly wouldn't use Q16 in anything, it's just not worth it in my opinion. Might as well run alcohol if your thinking of running Q16.
post #7 of 36 (permalink) Old 07-25-2013, 12:48 PM Thread Starter
post #8 of 36 (permalink) Old 07-25-2013, 01:23 PM
Can you post the Lobe Sep on the cam?
Chris Straub
Manufacturer of Valvetrain Parts
Custom Cams
www.straubtechnologies.com
cstraub is offline
post #9 of 36 (permalink) Old 07-25-2013, 01:30 PM Thread Starter
285/304 @ .050
116lsa
post #10 of 36 (permalink) Old 07-25-2013, 01:37 PM
Thats what I figured. Thank you for posting the specs. I don't know what the I/E ratio is so I don't know if the duration split is right or not.
Chris Straub
Custom Cams
cstraub is offline
post #11 of 36 (permalink) Old 07-25-2013, 01:51 PM Thread Starter
.100 - 88 / 68
.200 - 178 / 136
.300 - 266 / 189
.400 - 339 / 230
.500 - 392 / 275
.600 - 433 / 304
.700 - 449 / 322
.800 - 449 / 331
.900 - 455 / 342
post #12 of 36 (permalink) Old 07-25-2013, 01:57 PM Thread Starter
So what do you think about the results with the given information, fuel used and the humidity/temp?
post #13 of 36 (permalink) Old 07-25-2013, 02:33 PM
Quoted: 36 Post(s)
Q16 will make more HP than methanol.
B F Evans Race Parts
270-278-2376
Lem Evans is offline
post #14 of 36 (permalink) Old 07-25-2013, 02:38 PM
Duration is is pretty damn close. You may want to loosen intake .002 and try it one day. The exhaust could use more lift. Piston speed in this thing is quick. Exhaust could use a little help.
The lobe sep....I would tighten it.
Chris Straub
Custom Cams
cstraub is offline
post #15 of 36 (permalink) Old 07-25-2013, 02:41 PM
Quoted: 46 Post(s)
Q16 IS A GREAT FUEL . WE RUN IT A LOT,WITH NOS,AND NA
I SEE WHAT YOU MEAN ABOUT NOT BEING HAPPY, THAT'S A LOW NUM FOR THAT ENGINE
815-712-8738
Dynoed or Test ran
BOSS 429 is offline
