1994 Ford truggy (rock crawler / off road type rig - 460 Ford Forum
post #1 of 7 (permalink) Old 10-25-2010, 09:43 PM Thread Starter
Quoted: 6 Post(s)
Figured I had this posted on most other forums that I frequent, might as well put it up here too, maybe one of you guys know some one looking for a good wheeling rig.
1994 Ford F-250, (I'm pretty sure that's what year it is, never looked at the title after I bought it) but I do have a clean title.
Started as a 3/4 ton, regular cab, long bed, the frame was cut off about 18" behind the cab, then tube work was added.
Rear suspension is a 1/4 elliptical / 4-link setup, upper links are 1.5" .120 wall with 3/4" rod ends, Lowers are 2" .250" wall with 1" rod ends,
Rear diff is a sterling 10.25" with welded spiders, & 4.10:1 R&P
Front, The TTB was tossed in favor of a 4.10:1 "fuzzy locker" HP king pin D-60 out of an 87 F-350, (stock shafts, joints, & hubs)
The suspension started with stock springs & a shackle reversal, which got us 4" of lift, but recently it has been switched to 1/2 ton rear leaves up front, with these springs, & the shackles moved back up front, it pushed the diff forward about 3.5" (no hacking on the cab to fit 47s with very little lift.) shock mounts were relocated & 14" travel rancho RS5000 were installed,
Steering is full hydro with a surplus center 2.5" x 8" double ended ram, 1.5" .120" wall tierods, & 3/4" rod ends, Performance off road systems steering valve approx 4 turns lock to lock. stock, unmodified pump (still whines just like new )
Tires are 47" Swamper LTB, on 15" eaton/DYI beadlocks, I think they are only around 3" BS, no grinding was needed on the calipers to get them on the truck. Tires are probably 80%, they have a few cracks but seem to work very well.
The rest of the drive train includes, EFI 5.8L (351w), newer thermostat, radiator, & fan clutch, (the cooling issue turned out to be the thermostat, but that was the last thing we looked at, lol it'll run all day now) C-6 3spd auto, 2.7:1 Klune with cable shifter, hooked to a 2.86:1 borge warner 1356 with the slip yoke eliminator. (1330 U-joints throughout)
Body, the front fenders have been trimmed to clear the 47s & are in pretty good shape, there is a little body damage on the passenger side B-pillar (top side of the door jam) but it's not to bad. I have doors, they are a little rough, but very functional & complete.
Sliders are 1.75 .120 wall tube, they are a little light & show some pretty good wear, but they keep doing their job.
Roll cage is a standard hoop, spreader bar with bars going in to the center of the cab & door bars, all tied to the cab with 6"x6"x.125" floor plates, they are not tied to the frame, but have been stubbed below the floor boards so it could easily be done. The rear bars go out the rear window to the rear tube work, everything but the spanner bar & center bars is 1.75" .135 wall roll bar tubing.
Seats are RCI plastic seats with padded covers, mounted on the stock mount & track so they are adjustable, both seats have 5 pt harnesses with cam lock buckles (1/4 turn knob to release)
Winch is a smitty built XRC8 (8000 lb)
Newer skid plate, under t-case & Klune doubler box
New windshield installed 10-15-10
On board air installed using the A/C compressor with a couple gallon tank under the hood,
Also just got done with a fresh scuff & shoot paint job,
The only issues I know of on this truck are the whinning PS pump, I have a new one but refuse to install it til this one dies, I will through the new one on the front seat if the truck sells,
2 tires go low if it sets around a while, I air the tires up to about 10 psi every few weeks.
The other issue is the trans leaks, some times, lol.
It will sit for weeks & not leak a drop, then I'll move the truck & it will drip out a 1/2 quart in a few days time, I pulled the trans & replaced the pump/converter seal, since it looked like thats where it was coming from. but it still does it from time to time. other than that the trans works fine.
If I think of anything else I'll add it later, if there are any questions, don't hesitate to ask.
I'm asking $8000 & it is located in northern Nevada
Leroy Latham
skipped_link is offline
post #2 of 7 (permalink) Old 11-02-2010, 06:08 PM Thread Starter
Quoted: 6 Post(s)
Not many rock crawlers on here eh?
Leroy Latham
post #3 of 7 (permalink) Old 11-03-2010, 05:53 AM
cletus66's Avatar
Quoted: 8 Post(s)
No, but that is bad @$$ !!! I just got a subscription to 4 Wheel and Off Road magazine. More ideas on how to spend money.
Good luck sellin' your truck.
cletus66 is offline
post #4 of 7 (permalink) Old 11-03-2010, 08:41 AM Thread Starter
Quoted: 6 Post(s)
Thanks,
There are a few forums out there you can check out aswell if you really want the bug.
Leroy Latham
post #5 of 7 (permalink) Old 11-11-2010, 11:51 AM Thread Starter
Quoted: 6 Post(s)
Bumping it one more time.
Leroy Latham
post #6 of 7 (permalink) Old 11-11-2010, 01:47 PM
norm's Avatar
leroy,
have you listed it on here yet?
http://www.greatlakes4x4.com/forumindex.php?
norm is offline
post #7 of 7 (permalink) Old 11-11-2010, 04:29 PM Thread Starter
Quoted: 6 Post(s)
Originally Posted by norm View Post
leroy,
No I have not, I'm not an active member over there, & I don't want to be a troll & sign up just to try to sell something, lol,
Leroy Latham
