FUEL CELLS, FUEL PUMPS, REGULATORS, CARBS A
THIS SALE IS OVER.I will try and lock it. Look for more parts sale posts to come. Thank you.
I lowered prices on a few items. Parts that don't sell this round will be carried over to next round.
NEW TABLE OF GOODS COMING WEEK OF 12TH!!
1)"SOLD" Harwood Plastic Fuel Cell
2) "SOLD"Aluminum Fuel Cell
3)"SOLD" Aluminum upright fuel cell
4) Aeromotive 11101 series Fuel Pump (RED) For complete specs got to summits page. Used maybe 5 times and removed when I switched to alcohol. New 378.00 Asking 200.00
5)"SOLD"Comp Fuel Pump series 250
6) "SOLD"Aeromotive 13101 regulator
7) Aeromotive 13202 regulator with vac/pressure port & mounting bracket. Complete specs at summit. I used it approx 1 full season for transporting fuel from rear cell to front cell. 6 ports. 1 inlet, 4 outlets & 1 return.
New 185.00 Asking 85.00
8) 429/460 polished aluminum dual plane intake for dominator 4500 series. Most script removed when polished but looks like offy inlet. VGC! Uses felpro #1230 gaskets Comparable intakes like this are around 700.00 Asking 450.00. Very Nice Intake!!
9)"PENDING" 429/460 Nostalgic blower manifold. Back when they took dual 4 intakes and put blower tops on them. Uses felpro #1230 gasket. This came off of my car when I went to Hampton blower. No way to compare pricing so I'm asking 450.00
10) "PENDING" Hampton 2x4 blower top. VGC! Had 2 850 double pumpers on it and was on an 8-71 blower. It came with a blower I bought and I never used it. New 125.00 - 150.00 Asking 75.00
11) Mike Kuhl Enterprise 2x4 hi-rise carb/blower plate. Came off my 6-71 with 2 750 4500 series dominators on it. You can see the light milling on each end to clear the dominators butterflies. This is nostalgia at it's best! Mike Kuhl did a lot of blower parts through the years. Again, no way to price match..... Asking 250.00
12) 1 Holley Dominator 80556 4500 series 1150 CFM. Gone through by Pro Systems, I didn't use so they were boxed and put on the shelf. Has a cracked inlet so it will need a bowl. New 850-900.00 and up "SOLD ONE" Have the one needing a bowl left. Asking 500.00
13) 2 Holley 850 double pumpers. These are matched and came off of a blown BBF jet boat. I have never used them. Boxed and shelved. Will obviously separate with same conditions as others. Buy both, get a better price.
Asking 400.00 each (FUEL LINES PENDING)also have the pre-bent dual feed lines for an additional cost)
14)"PENDING" 2 Holley 750 dominators. 80186 4500 series. These came off of my car and stored. I'm selling them as good rebuild able dominators because of age. One needs a bowl. I used it on the fuel tank mentioned earlier. Asking 300-350.00 each
15)"SOLD" 2 K&N 11" x 4" air filters
16) TCI Power Glide trans case shield and pan protection plate. Ran it one season and after I cracked my case I went to a Reid case and don't need it. New 130-150.00 Asking 75.00 All brackets and bolts included.
17) Never used (mounted but never hooked up) MSD Timing control box #8680 . New 166.00 Asking 110.00
Thank you for your interest.
Auggie (330) 506-6875
