Early 460 ZF5 flywheel? - 460 Ford Forum
post #1 of 4 (permalink) Old 12-09-2008, 03:48 PM Thread Starter
What is the correct flywheel to run an early internal balance 460 with a ZF5 transmission? When I got the trans I got a almost new flywheel clutch and pressure plate that I'd use but the flywheel is for an external balance engine. Thanks.
cadunkle is offline
post #2 of 4 (permalink) Old 12-13-2008, 01:04 AM
Send a message via AIM to 78F150
I don't know about the difference between manual and automatic flywheels, but the guys at Mr. Transmission made a flywheel for an external-balance 460 fit on my internal-balanced 460 and didn't think a thing of it until I hopped in to take the test drive and the thing tried to shake the sheetmetal off...
78F150 is offline
post #3 of 4 (permalink) Old 12-13-2008, 12:34 PM Thread Starter
I imagine they didn't "make it fit" very well then. Probably just bolted it in. Just curious if an FE flywheel will work with the ZF (using an FE starter I presume), an what clutch bits I'd have to use for that to work. Or if there are any off the shelf zero balance flywheels that would work with a ZF. Another option I suppose would be to have the weight ground off my imbalance flywheel and have it zero balanced.
Prefer off the shelf parts before I do that though. Also want to run the largest clutch reasonable (12"?) as the truck will be used for towing as well as get a beating in the mud.
cadunkle is offline
post #4 of 4 (permalink) Old 12-13-2008, 01:12 PM
460 zf conversion
you can use a 390 flywheel on the internal balance 460 with a regular 460 zf starter, you will have to drill the bolt pattern in the flywheel for a 12" clutch, is your clutch for a solid flywheel or the dual mass flywheel? they are different, but both can be made to work, I have done many of these conversions and you would be best to have the newer flywheel 0 balanced, easier on the starter and the proper bolt pattern is already there, I have a couple in stock if you get stuck
turbo528onlp is offline
