94-95 F150 460 swap? - 460 Ford Forum
post #1 of 43 (permalink) Old 01-07-2009, 08:02 AM Thread Starter
jones's Avatar
How hard would it be to swap a 460 into a F150 that had a 302?
What about 460 headers for this year truck?
93 528cu Lightning
jones is offline
post #2 of 43 (permalink) Old 01-07-2009, 08:28 AM
Coupe Devil's Avatar
Its not hard. A few companies make the headers, Summit sells them. Its a pretty straight forward swap but you may run into valve cover clearance issues near the heater box on the passenger side. I dont remember. I helped a friend do one a few years ago. It was a pretty wild little street truck. From a dead stop if you romped it it would just ignite the tires. Stall it to about 1800-200 and stomp it and it would GO! Ran real good for a street truck, 80 mph in first gear with the C6.
1990 GT, 347 / 76mm turbo setup OUT AND GONE!
New setup going in. Dove headed 545 with a plate kit to 400, progressive, Th400 etc. etc. etc.
Coupe Devil is offline
post #3 of 43 (permalink) Old 01-07-2009, 08:36 AM Thread Starter
jones's Avatar
I found a Lightning clone with a carburated 302 and a rod hanging out the side for a decent price. Already has a back braced 9" rear axle supposedly.
I am really Jones'n to get something running and trying to figure how much work and money it would take to get my 472 into the truck. If it is something I can do real quick and purchase parts from the local parts store I'm interested.
I wonder what bolt pattern those lightning wheels have?
93 528cu Lightning
jones is offline
post #4 of 43 (permalink) Old 01-07-2009, 09:04 AM
Here is a kit to do it...
http://www.landlproducts.com/details...02&ItemID=1127
Wheels should be 5 on 5 1/2...
SteveL
“This is the point in the killing spree when you really should turn the gun on yourself…”
canzus is offline
post #5 of 43 (permalink) Old 01-07-2009, 09:11 AM
Jones if you could find a junkyard 3/4ton truck with a 460 you have all the parts to do the swap as they came factory with 460s.
Tom Williams
1929 Ford Model A
1972 Gran Torino Sport
1987 Thunderbird Turbo Coupe
2006 Ford Ranger
36 truck is offline
post #6 of 43 (permalink) Old 01-07-2009, 09:19 AM Thread Starter
jones's Avatar
I didn't know if the cross member was different between the F150 & F250. Plus, I know that on the older truck (73-79) the transmission mount is in a different location for the 460 factory equip trucks.
Is it just as easy as swaping them engine mount pads or will the entire cross member have to come out?
93 528cu Lightning
jones is offline
post #7 of 43 (permalink) Old 01-07-2009, 09:48 AM
The swap is easy. At least is was on my 93 Lightning.
All you have to do is get a set of conversion motor mounts and a set of headers.
There's a lot of room in the engine bay on the 96 & older F-series
Keith Blackburn
93 Pro-Street Lightning
598" of Jet-Boat Bob Power
5.89/9.33
http://www.nloc.net/photopost/showgallery.php?cat=717
Copperhead is offline
post #8 of 43 (permalink) Old 01-07-2009, 09:55 AM Thread Starter
jones's Avatar
Hey,, your that famous guy off tv! :lol: :lol: I couldn't remember what your screen name was.
Does the C6 bolt right in, no weird angles?
Do you know what the lightning wheels bolt pattern is?
93 528cu Lightning
jones is offline
post #9 of 43 (permalink) Old 01-07-2009, 07:11 PM
The C-6 is basicly an E4OD, just no overdrive. Many of the F-series came with a C-6, so finding one in a bone yard shouldn't be too hard.
My C-6 came out of a Lincoln and it has a funky mount, so I had to fab up a crossmember from 1-3/4" DOM tubing.
The stock bolt pattern on the 93-95 Lightnings is 5x5.5
post #10 of 43 (permalink) Old 01-08-2009, 01:03 PM Thread Starter
jones's Avatar
Thanks,
93 528cu Lightning
jones is offline
post #11 of 43 (permalink) Old 01-10-2009, 12:47 PM
schmitty's Avatar
Jones this is a real easy swap, you need the 460 motor mounts and frame perches from a 3/4 ton with 460, large radiator, and a decent set of headers. Get with ThndrChkn Doug on what he did for headers. You will need to take a blue flame wrench to the crossmember under the motor for oil filter clearance. I had to move my tranny crossmember, but the mount worked fine. All you have to do is drill a couple of new holes in the bottom of the frame. I ditched the upper braces on the tranny mount as I didn't want to deal with fitting them, and haven't lost any sleep over strength lost there. It was one of the easiest conversions I have ever done.
89 F150 mud drag truck
schmitty is offline
post #12 of 43 (permalink) Old 01-11-2009, 04:16 PM Thread Starter
jones's Avatar
Well, here is the new project! I hope it's a simple swap because I would love to bring it to the Bash.
93 528cu Lightning
jones is offline
post #13 of 43 (permalink) Old 01-11-2009, 04:25 PM
Hay I have a 91 F150 with a locked up 302. will this same swap work on it to. I have a 460 that needs a home.
Thanks Keith
res0rli9 is offline
post #14 of 43 (permalink) Old 01-11-2009, 09:43 PM
yep shouldnt be a problem. the bodies and frames are the same from 1980-1996... even to the point that you can swap front clips and have a 1980 look like a 1996
darrin1999 is offline
post #15 of 43 (permalink) Old 01-11-2009, 09:52 PM
8) thanks.
dont know why but my front end just got heaver
res0rli9 is offline
