HP vs TQ??? - 460 Ford Forum
post #1 of 13 (permalink) Old 06-27-2013, 02:26 PM Thread Starter
HP vs TQ???
Which is the most important to et??? HP or TQ?
How much of both would it take to get a streetable 3300lb(w/dvr) fox body to the high tens on motor?
I guess my 460 will make 525+- hp but I have no idea on torque. It is a 10 to 1 460, ported Victor Jr. and RPM heads, Comp Xtreme hyd flat cam and 950HP carb.
What is your take guys?
pjhmhsjsu is offline
post #2 of 13 (permalink) Old 07-03-2013, 03:18 PM
HP or torque? both, HP is a function of torque and RPM (HP=TxRPM/5250) T=HPx5250/RPM
if you do the math torque is at 460ft-lbs at 6,000 RPM. Some have said some strange things like torque is what pulls you thru the stripe. How can that be said when they both contribute.
69 Mustang ProStreet 580 E85
9.2 @ 148
70 Torino 521
11.5@119
BF Evans Race Parts
Dave D is offline
post #3 of 13 (permalink) Old 07-04-2013, 02:25 AM
RJP
Torque wins races....Horsepower sells cars.
RJP is offline
post #4 of 13 (permalink) Old 07-04-2013, 07:18 AM
If that is true we would all have diesel engines in our cars.
9.2 @ 148
70 Torino 521
11.5@119
BF Evans Race Parts
Dave D is offline
post #5 of 13 (permalink) Old 07-04-2013, 08:44 AM
I'm sure cost and manufacturing has nothing to do with what they put in our cars. I wish hp and tq were the only things that were used to pick engines to put in cars.
ford4wd08 is offline
post #6 of 13 (permalink) Old 07-04-2013, 04:43 PM
Its all relative when it comes to engines. If it wasnt, a 350 hp small block would perform like a 350hp big block. And we all know they dont. Compare those to a 350hp 3406 Cat and there is no comparison. Throw in a 350hp Screamin Jimmy 2 stroke and even the diesels dont respond the same. Thats where the difference in torque shows.
bgandt is offline
post #7 of 13 (permalink) Old 08-02-2013, 05:11 PM
Horsepower is only torque times rpm. A good way to think of it is imagine a single cylinder engine firing once a second & making a particular amount of torque (just rotating force). Now imagine you increase speed to twice a second - it still delivers the same thump but twice as often. So when they say these Formula One engines make 800hp from 2.5 litres, I'm not that impressed - its because they are doing 18,000rpm. They don't make much torque!
Duncan Mach72 is offline
post #8 of 13 (permalink) Old 08-02-2013, 11:06 PM
CarsByCarl's Avatar
Quoted: 94 Post(s)
Until you multiply the torque with the gears in a driveline that's set up for 18,000 rpm.
CarsByCarl is offline
post #9 of 13 (permalink) Old 08-03-2013, 02:48 AM
Quoted: 77 Post(s)
Whats the saying "RPM is your friend"
Most important is car set up, chassis and rear end. No use in having any power, if you can't put it to the ground.
bob460 is offline
post #10 of 13 (permalink) Old 08-03-2013, 11:02 PM
customblackbird's Avatar
I was once told a good and easy way to look at the difference in tq and Hp is this.
Hp is like water in a river, tq is the current.
Tq wins races, its literally what moves you or pulls you, Hp is wat keeps you going!
In response to diesel engines in cars, some sick @SS disel dragsters I'm cars that
Put so much tq down they are like rockets. Diesel motors at tq kings!
1987 Firebird
521 BBF 10.8:1 FAST EZ EFI 2.0
2004R GM OD Trans swap, NX NOS kit
customblackbird is offline
post #11 of 13 (permalink) Old 08-04-2013, 09:59 PM
HP is ALL that matters. HP is WORK. Torque is nothing more than a twisting force. Take your torque wrench, set it to 100 ft lbs and tighten up a bolt. You can hold it there all day and you are doing NOTHING
If you had a variable gearbox that keep the engine at peak HP RPM going down the 1/4 mile you would get the lowest ET possible regardless of what RPM that peak HP would be made at. Problem is having the right gearing to get and keep the engine in the power band.
68xr7cat is offline
post #12 of 13 (permalink) Old 08-07-2013, 08:18 PM
whoever told you about water / river got it a$$ backwards
HP is time , the less time to get to the flag or light wins
2slow is offline
post #13 of 13 (permalink) Old 08-08-2013, 07:37 AM
hookin78's Avatar
like to look at it this way....
Torque is the force the engine creates that can be used, Horsepower is how fast the engine can use it......
hookin78 is offline
