I have trimmed my core support to tuck the radiator up into the support as far as it will go. Only other room I can buy, would be to lower the radiator down to rest on the frame so I can tuck it up under the support lip, but then a good 4 inches of core would be blocked by the valanace, and front frame supports.
Doing some math, my motor plate mounts to the core is 7.5 inches. the front of the plate to the end of the CVR water pump is 6.5 inches.
I had bought the Contour dual fans, but they are 3 inches thick! wont add up.
Couple of options I would like opinions on:
1- see if I can cut or route the fan case to recess the snout into the shroud? Have to get the motor in first.
2- reverse polarity, cut the countour fan shroud down, and make them into dual pushers, from the front yes they will run in reverse, but they are curved blades. Cant flip the blades either, tried it.
3-by two small dedicated pushers, or one big dedicated pushers from the front...the two fan set up is AMP hog. Would one big be as good, better or worse than two smaller.
4-change to a mech water pump...really don't want to do that, I want to be able to cool the car in the lanes etc.
Just brain storming options. Looking for better ideas.
