Larry T's 552 build with stock p-51's 832hp-738tk
29K views 75 replies 28 participants last post by  Larry T
#1 · (Edited)
my 552 build started about 6mo ago,i am alittle slow but eventually i will get their.drag only motor for 3000lbs 94 mustang with powerglide 9'' rearend with 3.89 gears.i am hopeing to get the car done befor the end of fall so i can make a pass or 2. :D
D1TE block .060 over.
diamond flat top scj pistons .0128 average in the hole for about 13.2:1.
scat 4340 6.7 H beam rods.
scat 4340 4.5 crank internally balanced.
ford motorsports timeing chain set.
kaase p-51 heads +.100 valves Erson springs and titanium retainers "unported".
victor 4500 intake with the carb ears trimed to match carb gasket only.
comp cams roller cam
comp roller lifters.
lanati 1.7 rockers.
Hytec 3/8's x 9.100 and 9.300 push rods.
Jomar stud girdel.
Holley Quick fuel 1250 dominator carb.
Hvc 1" super sucker "10tk & 15hp gain" and 1" open spacer with a gain as well 2-3hp & tk.
dinoed with 2-1/4 cheby headers with charlies adapter. 8)
Kaase oil pump.
rod and main bearings were setup with .0025 clearance.
royal purple 15/40 oil and it did make a slight differance in hp and tk.
28.5* total timeing.
motor is setup to run 112 race fuel.
5000 736tk 700hp
5100 738 717
5200 735 727
5300 730 737
5400 725 746
5500 722 756
5600 723 770
5700 720 781
5800 719 794
5900 718 806
6000 712 814
6100 707 821
6200 699 825
6300 690 828
6400 683 832
6500 672 831.4
6600 662 831.4
6700 651 831
i purchased most every part from our vendors and members here on this forum,thank you all..........!
#58 ·
very nice build up. cant wait to see the finished product and final numbers.(et)
I used to do work with my dad until he passed. our finest work was a 70 nova with a 496 on a 9 inch tire that went 9 teens on a 200 shot. I had this car in 1988-89.
I wish I would have learned more from him, cherrish the time now and learn as much as possible.
#60 · (Edited)
6/14/09 update the car is now at home.we still have lots of work to do befor i can take her to the dragstrip.
the front end is from AJE it orignaly had motor mounts for the factory hook up.i wanted the motor plates so while it was at the chassie shop that was the time to do it,matt added the brace on each side.the motor plate and mid plate is from skinny kid.matt said he normaly puts the motor lower but the instructions didnt call for that.i have about 2 1/2 inches all around the steering rack and oil pan.
#63 ·
i am hopeing to have the car ready to go to shadyside by the end of july.we may get some extra time off from work depends on how the GM & Chrysler thing goes.i will keep you guys posted maybe some of that live close would want to meet up for the test and tune on thursday night?
#70 ·
7/26/09 update:
well guys i am not going to have the car finished until late september.i have many things done but i am only a one man band.i just finished the wireing i dont clame to be a wireing guru but the K&R kit makes things simpler.the next thing to tackel is the headers i am going to try and modify the hooker swap headers.the headers dont fit too well on the passenger side so i have purchased some J tubeing to fix the problem hopefully?their is a problem on the drivers side with the steering shaft rubbing may not be that big of a deal.
