Project 12.99 LTD finally... - Page 14 - 460 Ford Forum
post #196 of 366 (permalink) Old 04-26-2013, 11:51 PM Thread Starter
Quoted: 204 Post(s)
Cool Cam is NOT Damaged. Lifter plunger failure...
The pic kind of says it all...
Proceeding with installation of hydraulic roller cam with SOLID roller lifters.
224/234 / 110 +4 center 4 cylinders
228/234 / 112 +4 corner 4 cylinders
Lift with 1.8 rockers .600" intake and .620" exhaust.
26120 comp cams beehive spring package.
7122 comp timing set with torrington bearing.
Cam degreed in at +1 additional for chain stretch...
Cam grinder has not ever seen this type of failure nor have I.
A 950 hp is currently being built since the modded 750 flowing 840 cfm was pulling 1.6" of vacuum at peak HP WOT
http://R-H-P.biz
The Mad Porter is online now
post #197 of 366 (permalink) Old 04-28-2013, 12:42 PM
what is the cam core...? steel...? cast....? kryptonite....?
torino501 is offline
post #198 of 366 (permalink) Old 04-28-2013, 12:57 PM Thread Starter
Quoted: 204 Post(s)
First walk around. Worked Friday 11 to 8 and sat 11 to 10:15
Remember I had to install a steel dizzy gear.
Install, set installed height on the 26120 beehive springs, check each for full lift bind as my cam was a tic over the .600" lift max. Doing this in the vehicle was a pain in the azz...
Start up was uneventful or should I say routine. The no cam break in was a definite plus.
The pull to red line and into the rev limiter is much faster than before. Valve train is more stable imo. The idle burble is kind of unusual IMO. The phone microphone is a bit overwhelmed by the sounds...
https://www.facebook.com/video/embed...=4641518563271
http://R-H-P.biz
post #199 of 366 (permalink) Old 04-28-2013, 12:58 PM Thread Starter
Quoted: 204 Post(s)
Roller cam core is steel. The HFT cam was iron and a regrind of a BB ford core.
http://R-H-P.biz
post #200 of 366 (permalink) Old 04-28-2013, 07:54 PM
69F100's Avatar
Sounds good
My phone is the same way unless I back away from the truck some distance and then you can hear the cam mor
69F100 is offline
post #201 of 366 (permalink) Old 04-28-2013, 08:57 PM Thread Starter
Quoted: 204 Post(s)
First Drive Video...
https://www.facebook.com/video/embed...=4645350379064
Fuel pressure is dropping from 7 to 2.5 / 3 psi at WOT near 90 mph so a fuel system upgrade is next.
The current fuel pump is the summit branded high volume with all the 1/4" NPT fittings drilled out to .302"
http://R-H-P.biz
post #202 of 366 (permalink) Old 04-28-2013, 11:22 PM
with all that extra power scott, u might need to add some brakes to the car as well so you can slow down ! all wheel disc in the list to do to the car?
xoliex is offline
post #203 of 366 (permalink) Old 04-29-2013, 01:01 AM
Quoted: 77 Post(s)
MP what solid roller lifters did you use?
Cheers, Bob
bob460 is offline
post #204 of 366 (permalink) Old 04-29-2013, 10:37 AM
That idle is odd!! You can hear the typical idle sound from the rear of the car "bup-bup-bup-bup-bup" etc. but when you near the engine compartment you can also hear the "fawk wit me-fawk wit me-fawk wit me" idle! lol Cool!!
429TORQ is offline
post #205 of 366 (permalink) Old 04-29-2013, 11:40 AM Thread Starter
Quoted: 204 Post(s)
Cheers, Bob
I used the comp cams units with the forced pin oiling. This will be a long lived trouble free deal. The open spring pressure with the Beehives is about 380 pounds. This is fine for the hydraulic roller profile lobes I used.
The nice thing about these springs is that you can use less spring pressure vs a dual conventional spring. The comp web site does a good job of explaining why...
http://R-H-P.biz
post #206 of 366 (permalink) Old 04-29-2013, 11:46 AM Thread Starter
Quoted: 204 Post(s)
For the time being I converted to the largest HD 3" wide rear drum brakes I could find and have the HD SW sized drums with the oversized cooling fins.
To be frank I had not considered a disc conversion but it is a good idea no doubt !!!
Under very hard braking the rear brakes tend to try to lock up which is unnerving.
I have iron metallic pads up front.
http://R-H-P.biz
post #207 of 366 (permalink) Old 04-29-2013, 11:55 AM Thread Starter
Quoted: 204 Post(s)
Thanxx TQ.
This is a test bed for the 3 pattern cams before I offer them to clients.
The chassis dyno will give me more information about peaks and broadness of power band that I am after. It is currently limited to 6150 rpm but easily wants to pull past that. When I dyno I will try a pull with out the limit and see what the HP fall off looks like after the peak.
The old HP peak was 5650 rpm I will venture to be the new one will be closer to 6K or a tic less...
I ground on a 110 /112 lobe sep because of my 1.8 ratio rockers. Not only do the rockers make the cam look 2 degrees larger to the engine but they also increase the overlap triangle more equivalent to 109/111 which is where I would have ground the cam with 1.73 rockers...
http://R-H-P.biz
post #208 of 366 (permalink) Old 04-30-2013, 12:04 AM Thread Starter
Quoted: 204 Post(s)
Cool Better video showing 3 pattern cam idle quality...
http://youtu.be/btLt-MaiAbw
http://R-H-P.biz
post #209 of 366 (permalink) Old 05-02-2013, 09:41 PM
cletus66's Avatar
Quoted: 8 Post(s)
NIIIIIIICE !!!!!
cletus66 is offline
post #210 of 366 (permalink) Old 05-04-2013, 02:18 PM Thread Starter
Quoted: 204 Post(s)
Originally Posted by cletus66 View Post
NIIIIIIICE !!!!!
The last walk around vid is better quality...
Thanxx...
http://R-H-P.biz
