Installing the 10 point in Fox mustang - 460 Ford Forum
post #1 of 12 (permalink) Old 05-18-2012, 01:52 PM Thread Starter
This weekend I am having the 10 point installed , I was just checking any do's or don't with the Fox mustang? I am also welding in set of through floor subframe connectors. I understatnd it's not need for the speeds I'm planning for now but I plan to go faster later.
SRCA Dragstrip
Great Bend ks
89460fox is offline
post #2 of 12 (permalink) Old 05-20-2012, 01:21 PM
Install the sub frame connectors first.Then install the cage BY THE BOOK.
ITSA 91 is offline
post #3 of 12 (permalink) Old 10-06-2012, 01:08 PM
nuclearcobra's Avatar
Remember the tops of the cage have to be welded or you have to use gussets if you cant get to the very tops,this is one i finished last week and i chose to drop the cage thur the floor to get to the tops.
84 hatch scj headed 472" on 10" tires
nuclearcobra is offline
post #4 of 12 (permalink) Old 10-06-2012, 01:10 PM
Just remember if you do it that way the doors bars and the bars that go the trans tunnel have to be put in last.
post #5 of 12 (permalink) Old 10-06-2012, 08:53 PM
Israel's Avatar
I'd to read and follow a full write up on this,.....
Wife,........."You drove how far for that thing?"
Daughter,..."Theres no inside and it stinks."
Friend,......."Dude, thats a rusted piece of sheet."
Son,.........."This old car is cool."
USMC Security Forces, Kamiseya Japan, 0311
Israel is offline
post #6 of 12 (permalink) Old 10-09-2012, 08:04 AM
Talking
Sealing up the back and putting in the rear firewall tonite then its the scott rod dash he bought then wires and gages and fire it up time
post #7 of 12 (permalink) Old 10-09-2012, 08:17 AM
And 89460fox the reason i had to cut out that much of the rear is because when i went to weld in the plates for the back bars i found out the asshat my buddy had paint it also removed his spare tire well and tried to cover it up with several pieces of 3/16 steel plate and when he started to butcher and burn thur his frame with a stick welder, then he covered it up with tons of fiberglass and paint before he could see it and told my buddy its all welded in what a mess it was.
post #8 of 12 (permalink) Old 08-13-2013, 10:05 PM
Bluemule's Avatar
When y'all put the cage and sub frame connectors does the car need to be on the suspension or can it be on Jack stands?
Bluemule is offline
post #9 of 12 (permalink) Old 08-13-2013, 10:59 PM
bigblok86ranger's Avatar
You want the car to be on its own weight or else the car will not be square once done. You can have the car off the ground but make sure the suspension is supporting the weight and the car is level.
Eric Millard
bigblok86gt@yahoo.com
528ci of N/A power
Circle R Racing Engines
Trick Chassis
Beloit,WI 53511
608-313-9197
http://www.trickchassis.com/
bigblok86ranger is offline
post #10 of 12 (permalink) Old 08-13-2013, 11:28 PM
Bluemule's Avatar
Thats what I was thinking but wasn't sure . Thanks
Bluemule is offline
post #11 of 12 (permalink) Old 08-18-2013, 12:20 AM
I last 3 cars I did , I put them on four car ramps.
post #12 of 12 (permalink) Old 08-18-2013, 03:37 PM
It is definitely nice to have them up in the air when you install the cage so your back doesn't kill you for a week afterwards.
Eric Millard
528ci of N/A power
Trick Chassis
Beloit,WI 53511
608-313-9197
