Jed's 1967 fastback - Page 8 - 460 Ford Forum
post #106 of 117 (permalink) Old 08-27-2014, 10:12 AM Thread Starter
Inbred-jed's Avatar
Sweet man...can't wait to see it run..
Inbred-jed is offline
post #107 of 117 (permalink) Old 08-27-2014, 06:06 PM
Quoted: 39 Post(s)
Thumbs up
Originally Posted by Gydyup View Post
Sweet, amazing what a couple inches can do, yours look Dragster huge compared to mine. All in all the mini tub and notch was pretty easy.
Relocating my spring boxes was the hard part, just a lot of fabbing and welding. Now you can buy the pre fab mini tubs that look just like the stock, but that 3 inch bridge was a hell of a lot cheaper.
The Lunati crank showed up last night, waiting on rods, pistons, etc. Then off to the machine shop!
Everything has shipped...it will be raining parts the next few days.
B F Evans Race Parts
270-278-2376
Lem Evans is offline
post #108 of 117 (permalink) Old 08-27-2014, 10:08 PM Thread Starter
Inbred-jed's Avatar
suspension issue...
Hey guys i uploaded some video of my car launching...it seems to be porpoising a bit....any ideas? Its a 4 link...anti roll bar...29x12 hoosier...Strange DA shocks set at 4 clicks off soft on compression and 7 clicks off soft on rebound.....heres a video full speed ..2 slo mos ...and a full speed..
https://www.youtube.com/watch?v=2dIz...ature=youtu.be
post #109 of 117 (permalink) Old 08-28-2014, 05:53 PM
richter69's Avatar
looks like the front suspension has little if any travel.
69 Grande'
P51 headed 563
3070#'s
5.15 @ 134.89
richter69 is offline
post #110 of 117 (permalink) Old 08-28-2014, 05:55 PM Thread Starter
Inbred-jed's Avatar
Front is a strange strut...it only has 3 inches of travel...
post #111 of 117 (permalink) Old 08-28-2014, 07:18 PM
TOPHER1's Avatar
Jed
Jed from the video the tires are getting crushed (sidewall) tighten the rebound up 2-4 more clicks and the compression needs to go at least 2 if not 4 more clicks this will help keep the tires on from pushing back up into the car. I have been fighting issues most of the season but finally go it hooking right by tightening the rear AFCO DA shocks.. I set mine from stiff I am 12 from stiff on rebound and 8 from stiff on compression.. if you look under 1986 coupe build toward the end there is a video link of last time I was out..
Hope this helps and good luck.. Love the build that is one beautiful car..
Chris
TOPHER1 is offline
post #112 of 117 (permalink) Old 08-28-2014, 08:54 PM
NITROUS FORD's Avatar
Talking
hey in- bred were your located? iam from Cleveland area and I building a bbf in a 90 mustang coupe. was at Thompson raceway sunday for the cudra meet to watch some friends run there cars! was you there that day! nice ride!
NITROUS FORD is offline
post #113 of 117 (permalink) Old 08-29-2014, 07:15 AM Thread Starter
Inbred-jed's Avatar
No i wasn't there...I've only been there on saturdays...my home track is quaker...thompson is an hour north of me...I'm from warren...what track will you run at? norwalk?
post #114 of 117 (permalink) Old 08-29-2014, 02:41 PM
TOPHER1's Avatar
Jed
I posted a reply and did more reading about the strange DA you may need to send them back for a more custom valving since they only have 9 total adjustments and your running small tire high HP.. I have to send my Afco back to get them re-valved because I am almost as tight as the shock will allow.. You can also put a little more tire pressure to keep from crushing the tire so much with a little more shock stiffening.. Just a thought.. Good luck and let us know how it works out if you get out this weekend..
Chris
TOPHER1 is offline
post #115 of 117 (permalink) Old 08-30-2014, 12:09 AM
Location: Fortuna Ca Northern California in the redwoods
First you have done a fantastic job and have great car. You have a good eye for detail.
Just a few things that went through my mind on your car.
I went back through the build and from what I see is your car is all steel,stock glass and the motor is in the stock location.
So just a thought. Most strut cars have tube chassis with substantial engine set back and glass front wrap ---- glass doors and lexan windows. ----- This puts more static weight on the rear. In turn needing less front end travel for weight transfer.
Getting back to your car --- richter 69 --- touched on front end travel and I think he is on the right track. Super Stock cars are all steel heavy front cars with no problem wheel standing but look at all the front end travel they have to work with.
If we follow along this line of thinking using what we have the front struts should be setup for maximum travel on launch.
Another thing to think about is adding a 100lb ballast bar back by the rear bumper to increase rear static weight.
Another option is changing the front struts. Strange makes different stroke length struts.
Oh and one more thing that just came to mind is rear shock travel. Make sure with car race ready with driver weight that rear shocks have a minimum of 1" shaft showing so they don't bottom out and unload the rear tires.
QKiss is offline
post #116 of 117 (permalink) Old 08-30-2014, 07:25 AM
yea Norwalk and Thompson is my home tracks!
post #117 of 117 (permalink) Old 08-31-2014, 08:27 AM Thread Starter
Inbred-jed's Avatar
Thanks for the replies everyone...well I made quite a few passes this weekend and have determined it's definately not just the shocks...I went through pretty much every shock combo right up to stiff stiff...car felt like a brick...didn't porpoise but it spun like crazy lol....I think you guys are onto it with the front end travel and ballast...the engine does sit back slightly from stock but only an inch...car is still front heavy for sure...I think the convertor still may be an issue as well ...the convertor still does not flash above peak torque on the leave it's about 400 rpm short...I feel it's planting the tire causing the rear to drop but then it's laying on the convertor for .79 seconds not building any power until after it gets over the torque curve...sound plausible?...I definately think there is multiple factors
