My Bronco through the mud pit! - 460 Ford Forum
post #1 of 15 (permalink) Old 09-18-2011, 03:55 PM Thread Starter
Danny Cabral's Avatar
Saturday, I participated in Valley Truck & Off Road's annual Mud Bog Event and did very well. My '78 Bronco was one of the fastest trucks through the mud pit! It surprised a lot of spectators because they thought it was just a 'pretty street truck'. But after it went through the 160' mud pit like a rocket, the crowd was clapping & cheering. I got a lot of compliments and thumbs up from the staging lane on the return trip. Some people walked over to get a closer look at my truck/engine. My 508" engine sounded great going through the mud. (Some EFI/engine details: Link)
The Holley Dominator EFI & DIS ignition didn't bog down at all, even ¾ of the way through, where it was the deepest. In fact, my Bronco was traveling so fast, I had to come off full throttle in a few spots. Most of the participants had to hold the throttle down and hope the engine didn't bog down too bad, while crawling out the end. Inspecting the other trucks, I think I was the only older 'muscle truck' with aftermarket fuel injection, however, most of the carbureted trucks were performing well too. (Most of the rigs were classic Chevy trucks.)
The exterior of my truck didn't get too muddy because I've got good tire coverage (fender flares & big mud flaps). The engine compartment and chassis was covered with mud...bad. It was just nice to be able to perform so well and drive it home in one piece. (My drivetrain is heavily modified for a street truck.) In the past year, my engine has been through the following upgrades:
• Holley Dominator EFI System
• Fuel & Oil Pressure Transducers
• Autometer Hall-Effect VSS Sensor ECU Input
• Autometer Transmission Temperature ECU Input
• Crankcase Pressure Sensor (additional MAP sensor)
• Dual WBO2 Sensors with HBX-1 Bung Extenders
• Dual Knock Sensors (software tuned)
• Multi-Port Fuel Injection (dual-plane conversion)
• 1000+ CFM Ported Throttle Body
• Custom 60-2 Crank Trigger Ignition
• Distributorless Ignition System
• Sequential EFI - Cam Sync Conversion
• 5.7" Touchscreen LCD Monitor
• Custom 2” Traction Bars - ¾” Rod Ends
• Custom Cold Air Induction Kit
• Custom Mandrel Bent 3" Dual Exhaust (older upgrade)
Other specs can be read in my signature. Next year, I'm planning to install a small 100 HP shot of nitrous oxide - dry, direct port & progressive activation (ECU controlled with all it's safety parameters).
May God's Grace Bless You
Danny Cabral is offline
post #2 of 15 (permalink) Old 09-18-2011, 05:02 PM
Quoted: 7 Post(s)
Nice job!
Now you get to clean it!
1973 Mustang Convertible
TommyK is offline
post #3 of 15 (permalink) Old 09-18-2011, 10:10 PM
Touchngo's Avatar
Great Job! haven't seen you on here for a while, welcome back
Steve
2001 Ranger mud drag racer
632 ci with C heads and 2 -1150's
Touchngo is offline
post #4 of 15 (permalink) Old 09-19-2011, 12:39 AM
wvmudder's Avatar
X2, Nice to see you back Danny.
wvmudder is offline
post #5 of 15 (permalink) Old 09-29-2012, 03:55 PM Thread Starter
Last Saturday, I participated in our local mud bog again.
This year, it was a much nastier pit, and my truck got a lot dirtier.
More details under the video:
http://www.youtube.com/watch?v=do-qO...ature=youtu.be
post #6 of 15 (permalink) Old 09-29-2012, 06:03 PM
Quoted: 7 Post(s)
Looks like lots of fun. I didn't know anything like this still existed in CT.
TommyK is offline
post #7 of 15 (permalink) Old 09-30-2012, 06:10 PM
bbstickstang's Avatar
Send a message via Yahoo to bbstickstang
thats the way to drive like you stole it. Seeing the fruits of your labor now.
5.89@115 New best, 1.31 60', 12-5-15 All Muscle and No Steroids!
69fb mustang ,509,Liberty Equalizer,5.29 ,31x10.5 w ,3309 w/driver.
I get to feel the torque of a BBF 4 times an 1/8 and 5 times a 1/4.
www.classicgearjammers.org
bbstickstang is offline
post #8 of 15 (permalink) Old 09-26-2013, 04:36 AM Thread Starter
Here's the video of this past Saturday's mud bog run.
Remember, these are mostly street trucks just having fun.
It was a great run. It was also my first time with TSL Bogger tires (35x14.5-15LT).
I should've ran the N2O, because I noticed these tires "consume" a little power.
However, I confirmed the truck's optimum gearing - put transmission in 2nd gear & 4WD high.
(Yes, my Lentech Strip Terminator AOD still starts in 1st, then auto shifts into 2nd.)
The best part is, my Ford is kicking tail in Chevy country! FORD - Found Off Road Diggin'!
http://s41.photobucket.com/user/dcf1...c4f54.mp4.html
post #9 of 15 (permalink) Old 09-26-2013, 07:29 AM
kjett's Avatar
Quoted: 14 Post(s)
You need to make a road trip down to WV this weekend and come race with me
kjett is offline
post #10 of 15 (permalink) Old 10-11-2013, 08:57 AM
Mud Freak's Avatar
That thing real hauls through the pit!! Nicely done!!
When in doubt, hold'er to the floor.......I'm usually in doubt.
http://www.youtube.com/user/mudfreak79
President of the P.C.O.R.A.
Mud Freak is offline
post #11 of 15 (permalink) Old 11-24-2013, 01:14 AM
Have you ever been on fullsizebronco.com? The bronco seem familiar.
BRONCONUT is offline
post #12 of 15 (permalink) Old 11-24-2013, 05:39 AM Thread Starter
I have, but I rarely visit that forum.
post #13 of 15 (permalink) Old 11-24-2013, 08:30 PM
10-4 I see, you've been there since '06
post #14 of 15 (permalink) Old 12-17-2013, 10:34 PM
Youtube video link is gone. Do you have another link or is it the same as the photobucket vid?
Prizefighter is offline
post #15 of 15 (permalink) Old 12-18-2013, 02:08 AM Thread Starter
Originally Posted by Prizefighter View Post
YouTube video link is gone. Do you have another link or is it the same as the Photobucket video
YouTube video was last year's run.
Photobucket video is this year's run.
(Both videos are on Photobucket.)
