gearing ? - 460 Ford Forum
post #1 of 8 (permalink) Old 05-20-2013, 11:21 AM Thread Starter
gearing ?
Found out I need to change gears running 4.56 right now tried it in 4 low and was on the rev limiter from mid track on running in high and didn't hit second till the last 50 feet. the gears that will work in a 10.25 axle will be 5.13 or 5.38 tire are 36x17.5x16 paddles want to run high gear and its cheaper to buy gears then new paddles
muddog899 is offline
post #2 of 8 (permalink) Old 05-20-2013, 12:22 PM
kjett's Avatar
Quoted: 14 Post(s)
Why are you not shifting into 2nd until the last 50'? I'm running a 5.43 rear gear on the low side of a 205 t-case and I'm shifting into 2nd right out of the gate and in 3rd by 30-50' in the hole.
kjett is offline
post #3 of 8 (permalink) Old 05-20-2013, 12:47 PM
68formalGT's Avatar
Quoted: 33 Post(s)
How long is the track? What RPM do you have your limiter set at?
Joey
68formalGT is offline
post #4 of 8 (permalink) Old 05-20-2013, 02:15 PM Thread Starter
The track is 300 feet sand drag my shift point is setup up at 6800 rpm the trans is setup to shift at 6500 with a shift niod it will shift to third gear in low by 75 feet just run out of gear for a 300 foot track thats why I want to run two wheel drive on the high side
post #5 of 8 (permalink) Old 05-21-2013, 08:51 PM
prosandguy's Avatar
When I was running the red bronco, I ran a 5.13 gear front and rear, 33x16.5x15 casing with 16 Hookers on it. c-6, left off the trans brake, shifting at 6400, I would pull 2ns gear about 80ft out, and the shift light would just come on to catch 3rd as I was crossing thru the traps. a 36" casing tire is really big, seems like a lot of tire to get moving for ya
Big Broncos for life!
prosandguy is offline
post #6 of 8 (permalink) Old 05-21-2013, 09:47 PM
68formalGT's Avatar
Quoted: 33 Post(s)
I would think 5.38s so you could get into 3rd and not be on the chip. You could throw some 39.5 boggers on it if you decided to go to a bog and run it in low too.
Joey
post #7 of 8 (permalink) Old 05-21-2013, 10:15 PM Thread Starter
Prosand the tires are big but they were free so the price was right think the 5.38 are getting ordered next week since all be in morehead city nc for 3 weeks.68gt dont think all do mud did that for 12 years sands cleaner and doesn't beat up the truck as much
post #8 of 8 (permalink) Old 05-21-2013, 10:48 PM
68formalGT's Avatar
Quoted: 33 Post(s)
We're putting on two races in Clayton, one in Raton, and one in Dalhart, TX. Check out batcaveracing.com for rules and to see the posters with the pay-outs, they might change your mind.
Joey
