205 T-Case problem? - 460 Ford Forum
post #1 of 15 (permalink) Old 06-23-2013, 11:43 PM Thread Starter
redsuperduty's Avatar
205 T-Case problem?
I ran two passes in 4 lo at a local mud bog Saturday, truck ran great and everything seemed fine. I put it in 2 hi after my run to make all the tight turns back to the pits easier on the driveline. When I got to my trailer I put it back in 4 lo to load up, the front tires spun going up the trailer and the rear wasn't pulling at all. I'll tear into it today and see whats wrong, just wondering if any of you have ever had the same issue?
redsuperduty is offline
post #2 of 15 (permalink) Old 06-24-2013, 06:09 AM
575ciBronco's Avatar
I seem to remeber that happening to me back in the day....make sure both of the shift forks are moving freely.
Derrick
575ciBronco is offline
post #3 of 15 (permalink) Old 06-24-2013, 01:11 PM Thread Starter
It wasn't fully engaged, everything is good. I never knew it would do that, learn something new everyday!
post #4 of 15 (permalink) Old 06-24-2013, 10:22 PM
Andy Hall-Who Knew's Avatar
I have had that happen under load in the pit before. A ratchet strap around the T case will keep it from happening.
Andy Hall-Who Knew is offline
post #5 of 15 (permalink) Old 06-25-2013, 07:20 PM
jerad188's Avatar
Me 3, I actually swapped cases after it did it twice, thought the dogs on the gears may have been worn out
77 f150 short bed , 466 chipped at 6800 , comp 292 cam , 2800 stall c6, 5.13's/ 38.5's
jerad188 is offline
post #6 of 15 (permalink) Old 09-12-2013, 02:53 PM
mine is doing the same thing but it "feels" that it's engaged in 4-lo but only the front spins....any ideas where to look first? do I have to drop the case to inspect it?
69fb is offline
post #7 of 15 (permalink) Old 09-12-2013, 07:26 PM
raging85's Avatar
I dont think it is necessary to remove it right away, it could just be slop on the shifter pivots causing the one rail not to go fully into position. I've only seen a few do it but in both cases there was too much play in the pivots or a chunk of mud hanging it up.
Hope it turns out to be something simple for you
Derrick
raging85 is offline
post #8 of 15 (permalink) Old 09-13-2013, 03:25 PM
72puller's Avatar
Snap ring on the rear output shaft can get pushed off and they will do that. Take the rear yoke and cover off.
72puller is offline
post #9 of 15 (permalink) Old 09-14-2013, 02:22 PM
hookin78's Avatar
Yeah...... I had that happen once.... 2/3 tracksnap ring popped off, good thing I had the rev limiter set....!!!
hookin78 is offline
post #10 of 15 (permalink) Old 09-14-2013, 08:38 PM
kjett's Avatar
Quoted: 14 Post(s)
I'm dealing with that issue as well. Made my last 200' pass in front wheel drive I'm pulling my case down because it sounded horrible with all the grinding sounds coming out of it
kjett is offline
post #11 of 15 (permalink) Old 09-25-2013, 10:18 AM
Can't be that because 4-hi works and so does 2wd...(forgot to mention that in my response)
I will check to make sure it's fully engaging....but it does feel like it is.
69fb is offline
post #12 of 15 (permalink) Old 09-25-2013, 11:27 AM
kjett's Avatar
Quoted: 14 Post(s)
I decided to pull my original 205 apart and see what all was damaged in it. Doesn't look too bad, cracked the rear shift fork, started to strip the rear shift collar, and stripped half way down on the rear low gear where it meshes to the shift collar. So now the question comes if I want to pull apart one of the other cases I have to rob these few parts from them, or pony up the money for new parts. Priced them at Quad4x4.com and they want $100 for the low gear, $80 for an original or $40 for an offshore shift fork, and a whopping $175 for the shift collar, not to mention any new bearings/seals/gaskets that I'm going to need. So if I'm at least $315-380 just for the hard parts from them before seals and gaskets. Anyone know of any place cheaper or is that the going price for new replacement parts now a days? Just sucks knowing I can get good used 205s ready to run for $50-100.
kjett is offline
post #13 of 15 (permalink) Old 09-25-2013, 02:50 PM
Danny Cabral's Avatar
If you were closer, you could have my old Ford NP205 for $100. It's in great shape:
'78-'79 Ford ton parts
May God's Grace Bless You
Danny Cabral is offline
post #14 of 15 (permalink) Old 09-26-2013, 10:35 AM
72puller's Avatar
OK. I"ll remember that the next time it happens to me.
72puller is offline
post #15 of 15 (permalink) Old 09-29-2013, 12:30 PM
77mud's Avatar
I had that issue several times when i use to shift in and out of 4lo when racing got pissed one day and kicked the shifter and it started pulling all 4's again. now i just leave it in 4lo and let it go
'he never hit the brakes and he was shifting gears'
Larry (SLIM)
77 F-150 BB on 38.5's
77mud is offline
