Pulling a sled with my mud truck ?! - 460 Ford Forum
post #1 of 19 (permalink) Old 04-14-2014, 04:24 PM Thread Starter
jerad188's Avatar
Local fairground is having a truck pull next month, there having a "run what you brung" 4x4 gasser class to try and attract the local mud race community, I'm thinking I'm gonna run my truck with 38 boggers , I don't think my 14 bolt and d60 with 5.13s will come apart , does anyone think otherwise ?!
77 f150 short bed , 466 chipped at 6800 , comp 292 cam , 2800 stall c6, 5.13's/ 38.5's
jerad188 is offline
post #2 of 19 (permalink) Old 04-14-2014, 08:21 PM
Id find a set of 33 inch all terrains if I were you, depending on how much power your putting down that dana 60 wont live long with thoose big tires, u joint,yoke or ring and pinion failure. Where are you from?
71 Puller is offline
post #3 of 19 (permalink) Old 04-14-2014, 08:23 PM Thread Starter
jerad188's Avatar
Western Pennsylvania , I think I do have some 33 all terrains , not the best tread but ....
jerad188 is offline
post #4 of 19 (permalink) Old 04-14-2014, 08:32 PM
Ok,way to much traction with those boggers that equals driveline disaster. Good luck on your pull but beware, Its addicting.
post #5 of 19 (permalink) Old 04-14-2014, 08:38 PM Thread Starter
jerad188's Avatar
Thanks for the warning , and I'll leave the boggers at home. I've never done it but I'm guessing 4lo 1st gear?
jerad188 is offline
post #6 of 19 (permalink) Old 04-14-2014, 08:45 PM
Yes 4lo 1st gear by 75ft have your foot in the carb.
post #7 of 19 (permalink) Old 04-14-2014, 08:47 PM Thread Starter
jerad188's Avatar
So the object is to pick up as much speed before the sled hits the dirt and you start spinning? Sorry for my ignorance I've never paid close attention to pulling
jerad188 is offline
post #8 of 19 (permalink) Old 04-14-2014, 08:58 PM
yep,you got it. how many springs do you have in the rear.
post #9 of 19 (permalink) Old 04-14-2014, 09:05 PM Thread Starter
jerad188's Avatar
Not near enough I know that! I only got 4 because there 6" lift springs, i do have another pack I could swap in for that event it wouldn't take long, I have good strong ladder bars also
jerad188 is offline
post #10 of 19 (permalink) Old 04-14-2014, 09:37 PM
D Pope's Avatar
Springs are half the battle in a truck pull. If you keep the back end from squatting under load then you're pulling weight off the sled and making it easier to pull!
1949 Mercury coupe
Nosed, Decked, Frenched
58 T-Bird interior
472 w/toploader 4 speed OD
Performer RPM w/Holley 3 barrel
Isky 304 degree solid cam
Narrowed 3.25 9.5 inch with Detroit Locker
D Pope is offline
post #11 of 19 (permalink) Old 04-14-2014, 09:44 PM Thread Starter
jerad188's Avatar
I have the perfect set I do believe , thanks guys
jerad188 is offline
post #12 of 19 (permalink) Old 04-15-2014, 02:56 AM
WFO
Yeah block the rear suspension if you can, much travel and truck will bounce!
WFO is offline
post #13 of 19 (permalink) Old 04-15-2014, 08:45 AM
hookin78's Avatar
Hmmmm,.... sounds like a lifted truck.....
if it starts bouncing....... LET OUT....!! It aint worth it....!
Lifted trucks n truck pullin are sometimes not a good combo...
hookin78 is offline
post #14 of 19 (permalink) Old 04-15-2014, 09:50 AM
With 513s I would use 4lo and 2nd gear
79Puller is offline
post #15 of 19 (permalink) Old 04-16-2014, 03:29 AM
WFO
But it's an automatic, stick with 4lo 1st gear.
WFO is offline
