Catalytic converter questions - 460 Ford Forum
Magnaflow
post #1 of 5 (permalink) Old 09-16-2013, 12:48 AM Thread Starter
Wow no one posts in here very much, I hope this forum is still monitored.
What cats would you suggest for a 528" big block in a 6200 lb truck?
I have a non-catalyst 1986 f350 that I'm currently building an E85 big block for. I live in California so my concern is with the smogability of my combo. I understand that N0x emissions are raised significantly by higher compression, so if I increase N0x with 12.5:1 compression, can I run a couple cats to decrease N0x back to near stock "non-catalyst" numbers?
There needs to be more tech on this stuff for us California bbf'ers!
86f350 is offline
post #2 of 5 (permalink) Old 09-16-2013, 12:42 PM
LockNLoad's Avatar
California has really gotten jacked up about changing/modifying CCs, here is a link to the CARB site on Executive Orders for cats and other vehicle mods:
Link
This Link will take you to a "pick what vehicle you have" page to search for CARB approved cats, I assume your truck is not stock (528") but this may help in getting you close to what you need, also if you have a lot of visible mods you may have to go through the referee process to get smogged/registered.
Here is a Link to some info about the referee process.
Hope this helps,
Greg
2013 Mustang GT, Bama tune, Exhaust modded, Custom rear air diffuser, FRPP 4.10s, welded axle tubes, BMR Drag Race Package (Level 2), BMR Adjustable Panhard Bar, Weld S71 15X9.25
Mickey Thompson ET Street Radial 315/60R15, JPC Line Lock... more to come
Link to pic of car
LockNLoad is offline
post #3 of 5 (permalink) Old 09-16-2013, 03:49 PM Thread Starter
Thanks for those links, I'm reading through that first database now. It looks like there is only one aftermarket cat available for use on pre-obd vehicles, but no information about adding cats to non-catalyst vehicles. I guess ill just have to do a visual inspection like you mentioned and hope for the best.
86f350 is offline
post #4 of 5 (permalink) Old 09-16-2013, 04:27 PM
LockNLoad's Avatar
I kinda misunderstood your question, I didn't really understand that you are trying to 'add' cats to a truck that has never had them... your best best is to call and talk to a referee Here's a list of the different collages around California that have referee stations. My thoughts on this are, if you are running E85 and even though you are bumping up the compression you should still be OK smog wise without cats, because E85 is a cleaner burning fuel, shoot if it was me I wouldn't even worry about cats for now I would wait to see if it passes without them, then worse comes to worse and it doesn't pass for NOx then I would just get some high flow cats and throw them on.
I am going to be doing something similar on my '13 Mustang, I'm going to convert my fuel system to be E85 friendly then I'm going to run high flow cats (because I have to have cats), I'm hopping that with the cleaner fuel I will still 'burn' clean out the tailpipe for smog. I'm sure I will have to go to a referee though.
Greg
Link to pic of car
post #5 of 5 (permalink) Old 01-26-2015, 05:24 PM
IF I had to pass smog in commifornia ( I dont I am in indiana) I would set my fuel system for methanol!!! (CHEAP) then I could run E85 or add gas to pass smogg!! Just a thought!!
chuck_b24 is offline
You may not post new threads
You may not post replies
