501 BBF Cam Degreeing - 460 Ford Forum
Jon Kaase Racing Engines Jon Kaase is considered one of the best minds in the world of Big Block Fords and has created many parts to help enthusiasts with their 460 based projects. Gentlemen start your questions…
Photobucket
post #1 of 6 (permalink) Old 01-28-2012, 09:50 AM Thread Starter
Need some thoughts on cam degreeing. Have a 501 with p-51 heads, (previous owner had steel cj's), in a 3000 lb. car with transbrake and 14X32's. Runs 9.15 to 9.20's depending on track surface. Has a 10 year old or better solid roller cam, previous owner of short block had no cam card but was told it was 286@50, 750 lift. Seems to be about right from my checking. It's in straight up at 103. Need the cam guys thoughts on retarding this thing to about 108 or 110 in this application.
quikmule84 is offline
post #2 of 6 (permalink) Old 01-30-2012, 10:17 PM Thread Starter
jon, charlie, any comments would be helpful.
post #3 of 6 (permalink) Old 07-26-2013, 08:53 PM
cam degreeig
Are you sure about that 103 degrees ? If so it way advanced and you'd most likely do well to back it off. From my experience small block cams are anywhere from 106-112 and BB generally 108-114. I hadn't done this myself cause I've always had a cam card ( maybe you can shed some light on this Jon ) , but to degree the cam to coincide with the max cylinder pressure as the cam timing will have a great affect on it.
trabdady is offline
post #4 of 6 (permalink) Old 07-27-2013, 02:45 PM
557MAV's Avatar
What is the name and #s on the cam. With #s you can call manufacture to get specs. Have done it a few times. Some have changed part #s but are still made with some variance.
1972 maverick 3200lbs street car. Steel and glass.
Jon kaase 598. 8.57@ 160
557MAV is offline
post #5 of 6 (permalink) Old 08-09-2013, 12:43 PM
Without knowing what has been done to the heads I can't say for sure but the P51 stuff I have cammed doesnt' need a single pattern cam.
Chris Straub
Manufacturer of Valvetrain Parts
Custom Cams
www.straubtechnologies.com
cstraub is offline
post #6 of 6 (permalink) Old 08-11-2013, 12:05 PM
Quoted: 38 Post(s)
The P51 package does very much need a dual pattern cam.
B F Evans Race Parts
270-278-2376
Lem Evans is offline
