485 cu.in. build - 460 Ford Forum
Jon Kaase Racing Engines Jon Kaase is considered one of the best minds in the world of Big Block Fords and has created many parts to help enthusiasts with their 460 based projects. Gentlemen start your questions…
Photobucket
post #1 of 4 (permalink) Old 11-06-2012, 08:45 PM Thread Starter
485 cu.in. build
I am considering changing my pulling truck to a 485 cu inch class and was wondering what would be the best combo. I now have a 4.14 stroke crank and .080 over bore and P-51 heads. The max bore spacing alowed is 4.9 inches. Any heads are allowed ecept Hemi. Single four barrel carb. no sheet metal or tunnel ram manifolds. Thanks for your input.
fpuller is offline
post #2 of 4 (permalink) Old 11-07-2012, 10:00 AM
CarsByCarl's Avatar
Quoted: 85 Post(s)
A 1.25 CD +.080 stroker piston with a 7.1 rod and an offset ground factory crank will net you 483 cubic inches with a 1.82:1 R/S ratio.
CarsByCarl is offline
post #3 of 4 (permalink) Old 01-15-2013, 09:25 AM
Quoted: 105 Post(s)
I have a few engines out there in that class with a slightly different set-up for lower budget.
Offset ground FORD crank to Mopar journal size and 3.975" stroke; a bushed pin end Mopar 440 rod 6.760" long, (could be aftermarket replacement or not) and a 4.390" bore with a piston compression height of 1.560".
Those P-51 heads and a Trick Flow Dominator manifold with a 1,250cfm carb. A custom cam to match your vehicle and running gear.
post #4 of 4 (permalink) Old 01-15-2013, 01:13 PM
hookin78's Avatar
The term " Best Combo" will be different depending on budget .....
factory block with standard Production "style" heads.....
Or
Max Effort
Aftermarket Block 4.700 bore destroked
A-style heads
wicked valvetrain and 10,000 plus RPM capable
Big difference
hookin78 is offline
