460 Ford Forum (http://www.460ford.com/forum/)
-   Wheel and Tire Tech (http://www.460ford.com/forum/64-wheel-tire-tech/)
-   -   Tire To Fenderwell Clearance ? (http://www.460ford.com/forum/64-wheel-tire-tech/164261-tire-fenderwell-clearance.html)
colormebad 05-20-2013 04:57 PM
How much clearance would work ok' With a 29.5X10.5 Drag Slick ? I have 1" in the front and rear of the fenderwell...
QUICKSHIFT 05-20-2013 06:29 PM
Is the tire set in or mounted on a off set wheel that sticks out? What width rim? The reason I ask is if the ctr of the wheel/tire lines up with part of the fender that has the 1" clearance, the tire MAY rub if it grows. Wider rim = less growth. More info please.
colormebad 05-22-2013 07:04 AM
It dont seem to stick out at all...Seems just right....Its a 10" rim...The center of the tire is no where close to the outside , where the 1" clearance is..I will post a pic where i reworked that area to get 1" clearance , with the tire on..
Anquia 03-29-2014 10:43 PM
ive had 1" but it rubbed when i ran the 1/4 .....yyyyyyy.160 plus ...it seems to grow
xoliex 04-22-2014 05:24 PM
i have a 29.5x10.5S on a 12'' rim and in the front i had a .75 clearance in the front and 2 inches in the back. on the burnout and at the end of the track it was EVER SO SLIGHTLY rubbing. so i'm assuming i was even getting those tires to grow 1.5 inches.
i clearanced the front of the fender another 1/4'' and no more rubbing. so i think you got it covered with 1'' on both sides.
Powered by vBulletin® Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
