429 install into 1968 montego wagon - Page 8 - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Car Buildup Forum
Car Buildup Forum A place to detail your car build and chronicle your progress as you put together your BBF powered vehicle.
  #106
Old 01-26-2013, 05:41 PM
68montego's Avatar
68montego 68montego is online now
68montego First On Race Day
Default Re: 429 install into 1968 montego wagon
No I do have a camera but I have no computer to upload them onto. Gasket seemed to be blown through in a little section no more than a 1/4 between the two cylinders. Heads straight and no leaky valves. Already slapped it back together. So I'm hoping for the best!!!! We will see tomorrow I guess. I wanna let the rtv dry overnight.
Sent from my SCH-I535 using AutoGuide.Com Free App
Old 01-27-2013, 02:21 PM
68xr7cat 68xr7cat is offline
68xr7cat Driving a Ford
So you get it up and running? I'd take a good look at your vacuum advance make sure it is working correctly. Pre-ignition could have caused the failed head gasket and a vacuum advance not working correctly can do that.
Steve
  #108
Old 01-27-2013, 03:57 PM
68montego's Avatar
So today I dropped the distributor in it. It fired right up and purred like a kitten thats secretly a lion. I set the timing on 10*btdc. And I have the vacuum advance disconnected. My mechanical advance takes it from 10* to 50*. Was told I have plenty of mechanical advance to conpensate for screwed up vacuum. Let me know how you feel about timing and the vacuum situation. But just have to dial in the carb and timing. It twists my wagon though. Lights them up as well pretty good. I have a 160* thermostat and it sits at 170*.
  #109
Old 01-27-2013, 05:49 PM
A70Maverick A70Maverick is offline
A70Maverick Driving a Ford
50deg of advance is too much! Need to get it down to around 32-38 degrees total. Running without vacuum advance is fine, won't hurt anything.
557ci 70 Maverick, 8.93@151 1.28 60ft.... So far!
'71 Torino Cobra Prostreet, 429/C6.
  #110
Old 01-27-2013, 06:21 PM
Like maverick said 50 deg mech. advance is too much. Sounds like your dizzy is screwed up. The adv. weights and springs are under the plate the points bolt to. With initial set at 10 deg, you want another 26 deg. give a total of 36 deg. all in by about 2,500 rpm.
Best performance usually is between 36 - 38 deg. on these engines. The question is if your gas is good enough to run the correct timing without detonation. I am thinking that will be no. You may need to cut back the total to about 32 deg. with all in by 3,000 RPM.
The vacuum advance helps mileage and drivablity under part throttle. I'd replace the vac. adv. with an adj. one and limit full vac. to 15 deg.
If this is going to be a regular street car I'd run an 180 deg. thermostat as 170 deg. is a bit on the cool side and will result in more wear. Now it will help as far as reducing the chance of detonation if that becomes an issue.
Congrats on getting it up and running. Certainly is a cool ride!
Steve
  #111
Old 01-27-2013, 07:52 PM
68montego's Avatar
Yeah still have to adjust those. It was the one that came with the engine. Everything inside looked like it was replaced and new so I used it. Guess ill have to mess with it. Yeah I figured that was a bit high. I would like to get electronic ignition for it but that will have to wait. Thanks steve!! I love my wagon. Tomorrow I'm gonna mess with it more. Still have some litttle things to do like hook the kickdown rod up and fill it with some antifreeze.
  #112
Old 01-27-2013, 10:24 PM
Wagons are cool !
If I was to guess someone did not assm. the dizzy correctly. Was nice of them to put all new parts in, now you just have to assm. it correctly. LOL
Here is a link to a write up someone did should help. Click on the blue words will take you to some pictures that will help. You can buy spring kits for about $5 which come with instructions and show you the different curves you can make. Not to keen on his solution.
http://www.gofastforless.com/ignition/advance.htm
  #113
Old 01-29-2013, 01:40 PM
68montego's Avatar
Yes I guess so... lol ill have to get that spring kit and fix this bad boy.
  #114
Old 02-02-2013, 03:40 PM
68montego's Avatar
Well I think my transmission died!!! Its just slips when its in gear and the fluid smells burned. Doesnt move til the rpms get pretty high then it sluggishly moves forward. Worked great up until about an hour ago. Went to drive off from a light and it wouldnt go. Limped it home.
  #115
Old 02-04-2013, 10:58 AM
68montego's Avatar
  #116
Old 02-15-2013, 04:39 PM
68montego's Avatar
Anyone have a c6 or rebuild them around here? Mine died and I'm in desparate need!! I had fun driving it for two days...basically a tease.
  #117
Old 02-15-2013, 07:02 PM
Dman64's Avatar
Dman64 Dman64 is offline
Dman64 First On Race Day
Default 429 install into 1968 montego wagon
No wreckers near you? Or pull it and do put new fibres and steels and seals in it, they are a straight forward rebuild.
D
Sent from AutoGuide.com App
1964 F100 466 zero decked fuelie 7cc dish pistons, with RHP 2.11 1.65 budget D3 heads, Voodoo cam 219/227, rpm intake, eddie 750 performer carb, MSD Ignition, Re-Curved Duraspark Dist, 4R70W Trans with Baumann Re-cal kit, US Shift electronic Trans controller with B&M Megashifter, 2500 Dirty Dog Convertor, 3.50 gears with detroit locker.
http://www.flickr.com/photos/36499599@N04/
http://www.youtube.com/watch?v=rbl-v...3&feature=plcp
  #118
Old 02-16-2013, 01:02 AM
Like Dman said not hard to rebuild a C-6. If you need a good rebuilder I can recommend one of the best.
  #119
Old 02-18-2013, 12:54 PM
68montego's Avatar
You need a special tool though right? I talked to a couple of shops and they said almost a 1000 $. I don't have much money to spend which is why i was hoping for a good used one.
  #120
Old 02-18-2013, 03:51 PM
You have a PM
Steve
You may not post new threads
You may not post replies
Powered by vBulletin® Copyright ©2000 - 2013, vBulletin Solutions, Inc.
