great lakes dragway test and tune 4-13-13 - Page 2 - 460 Ford Forum
Go Back   460 Ford Forum > Full Race Tech > General Race Tech
General Race Tech All other topics, such as Fuel Delivery, Ignition, Engine, Safety, Data Aquisition, Suspension, etc...
  #16
Old 04-21-2013, 10:32 PM
twekd1 twekd1 is offline
twekd1 Driving a Ford
Originally Posted by BOSS 429 View Post
what rpm are you crossing the line at? 3.70 gear might not be enough?
i had a 5700 rev chip and i was bouncing off the limiter right at the end.
Old 04-22-2013, 07:25 AM
bigblok86ranger's Avatar
bigblok86ranger bigblok86ranger is offline
Super Moderator
bigblok86ranger Spreads the gospal of BBFbigblok86ranger Spreads the gospal of BBFbigblok86ranger Spreads the gospal of BBFbigblok86ranger Spreads the gospal of BBFbigblok86ranger Spreads the gospal of BBFbigblok86ranger Spreads the gospal of BBF
Send a message via Yahoo to bigblok86ranger
Originally Posted by bigblok86ranger View Post
Try 7.5 psi fuel pressure, hopefully you have a 1/2" or -8 minimum fuel lines.
What needle and seats are in the carbs? Put the good viton tipped .150" seats in if you don't have them already and get the fuel pressure up. I think the better needle seats will allow ~9.5 psi. Someone will correct me if I am wrong.
The Holley Blue is only rated to around 550hp I ran one with around 690hp but with only one carb you may need to upgrade your pump.
Eric Millard
bigblok86gt@yahoo.com
528ci of N/A power
Circle R Racing Engines
Trick Chassis
Beloit,WI 53511
608-313-9197
http://www.trickchassis.com/
"LOL, WE DONT RACE DYNOS" Quoted for the truth!
  #18
Old 04-22-2013, 08:58 PM
Correction i have a black pump on the carbs and a blue pump for the nitrous.
So besides fuel pressure what else can it be? What number squirters should i run and cam color? (it has the large 50cc accelerator pumps)
watching the car i see its not puffing fuel smoke when i stall it out but it does when i floor it.
I am sure the carbs used to run alcohol, could something be drilled out that i should look for?
The ignition system is a old school msd 7al-2, msd pro billet distributor, and a msd pro power coil.
  #19
Old 04-30-2013, 12:28 PM
A70Maverick A70Maverick is offline
A70Maverick Driving a Ford
If its doing it's surging at WOT, the squirters or pump cams have nothing to do with it. If they were Alky carbs before, the metering blocks and main body passages are probably too big. The Surging sounds like a fuel delivery problem to me....
557ci 70 Maverick, 8.76@153 1.25 60ft.... So far....
  #20
Old 05-09-2013, 09:52 PM
so after playing with jets last time out I realized carb tuning is expensive and difficult. I am all in now i purchased 2 full jet kits and 2 full accelerator pump tuning kits. I also purchased a Innovative motorsports LM2 data logger with 2 o2 sensors. it has the capability of adding a ton of sensors. right now it will have rpm and air fuel in each header collector. wish me luck
  #21
Old 05-10-2013, 01:35 PM
stang93mustang's Avatar
stang93mustang stang93mustang is offline
stang93mustang First On Race Day
A little late now but I would say get a victor jr. manifold with a 1050 dom. and you good to go.
You would need a pump pressure of at least 12-15psi to handle demand. Need 6 1/2 to 7 1/2 psi from regulator to carb. Check float height adjustment. (This is for single carb tune but you can get the ideal)
93' LX hatch, 460 with mods and factory heads, TH400 trans, 9" w/ 3.89 spool. Best (so far!) of 10.04 @ 133 mph w/ 1.36 60'
Wanna see a low budget BBF run: (I know..the date trips me out!)
https://www.youtube.com/watch?v=70l4...e_gdata_player
I'm not SAYING, I'M JUST SAYING!!!
  #22
Old 05-12-2013, 01:22 AM
Pull the motor out and dyno it. Best $$ you'll ever spend! You already spent WAY more than a dyno session trying to figure it out!
